01-13-2019, 02:22 PM   #1
K3-II + DFA 50 + Pixel Shift Resolution
I'm just pushing my K3-II's sensor to its limits because K1-II is on the horizon
I rarely use this feature but it's very handy when you need more resolution. I see lots of pictures with K-1 and DFA* 50 combo but not so much with crop body so if anyone is wondering...
There may be better results with more steady situation but....
Focus mode: Spot
White Balance: Cloudy (forgot it to change)
Shutter Speed: 1/4s
ISO: 100
Apperture: f/4
Distance: ~1 meter.
Focus Point: between toys
Original
Crop
Many refer pixel shift resolution to sharpness but imho it's incorrect.
01-13-2019, 03:24 PM   #2
Ash
Community Manager
Ash's Avatar
To you is the effect of pixel shift not as good as sharpening in post-processing images?
01-13-2019, 03:33 PM   #3
Wheatfield's Avatar
You mean to say pixel shift is not as good as sharpening in post-processing images?
Pixel shift isnít doing the same thing. Pixel shift in the Pentax ecosystem is about increasing bit depth. I have, with a few images, seen an apparent increase in resolution with it, but it is just colour acuity increasing. I believe Olympus uses pixel shift to increase the pixel count of the image rather than increasing the bit depth.
01-13-2019, 03:36 PM   #4
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by Lev Quote
Very detailed indeed... Excellent result - thanks for posting!
What I read, Ash, is that pixel shift and sharpening aren't equivalent. Pixel shift shows an increase in actual detail, whereas sharpening gives a perception of detail.
Maybe the OP will correct me if I've mis-interpreted here
01-13-2019, 03:36 PM   #5
Ash
Community Manager
Ash's Avatar
I appreciate that, and agree they aren't equivalent effects on image quality, but I wanted to get the thinking of the OP, notwithstanding the probable language barrier with what the intended message was from his observation.
01-13-2019, 03:37 PM - 1 Like   #6
Ash
Community Manager
Ash's Avatar
You beat me to it.
01-13-2019, 03:40 PM - 1 Like   #7
Senior Moderator
BigMackCam's Avatar
You beat me to it.
I have occasional moments of lucidity... Before I drift quickly back to my normal state
01-13-2019, 03:45 PM   #8
Lev
Yep, that's what I mean. In other words, pixel shift resolution doesn't improve lens performance regarding sharpness, it just adds extra resolution, details to the image.
01-13-2019, 03:57 PM   #9
Ash
Community Manager
Ash's Avatar
May these moments happen more often.
Thanks for that. Precisely the clarification I was after.
01-13-2019, 03:57 PM   #10
Lev
Well. yes and no of course image taken with pixel shift will be always better overall but what I'm trying to tell is that you "help" sensor to gain more details not the lens itself. So when someone says pixel shift image is sharper it's irrelevant because you link the sharpness to lens in the first place.
01-13-2019, 09:10 PM - 1 Like   #11
UncleVanya's Avatar
Pixel shift should reduce interpolation errors where a color is assumed to be present due to the adjacent color patterns. This could increase actual detail but not pixel count. The Pentax approach has advantages and tradeoffs.
01-21-2019, 01:06 PM - 1 Like   #12
Lev
I missed this in your reply... You're absolutely right, I meant exactly what are you saying here.
02-25-2019, 06:05 PM - 1 Like   #13
richandfleur's Avatar
Pixel Shift improves the optical resolution of the image and provides more accurate colour capture. This can then be sharpened like any picture can, but there is more detail to start with.
As mentioned above, other manufacturers offering similar functions are using it to increase the pixel resolution, so that the final image can be printed much larger than the standard single shot dimensions.
Both do not handle movement very well, and the approach is to identify movement between shots and in that area just use the data from a single frame.
It's pretty cool tech, and only Pentax is taking this increased optical performance approach, but then they always have been focused on superior image quality.
Pentax could technically provide the option to do either approach via firmware update at a later date, but they're not particularly big on that sort of later development.
To the OP, thanks for sharing your experiences.
camera, crop, dfa 50 pixel, dslr, focus, k3-ii dfa, photography, pixel, pixel shift, resolution, shift
Pixel shift with pixel artefacts Dericali Pentax K-1 4 07-18-2018 12:57 PM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 2 07-16-2018 02:15 PM
SR II on K-1 MKII will offer Dynamic (handheld) Pixel Shift Resolution alpheios Pentax News and Rumors 84 02-22-2018 02:21 PM
Samples of Pentax K-1 Pixel Shift Resolution system - pre-production firmware bachtran Pentax K-1 18 04-11-2016 04:36 AM
Can't use Pixel Shift Resolution in B mode astrojim Photographic Technique 14 03-29-2016 04:11 PM
All times are GMT -7. The time now is 01:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
