Originally posted by sutherland Yup, I apply individual processing to each image. If I return home with 400+ files, I will usually just drag over 40 or 50 at a time to process them.
I plow through mine at a rate that makes my wife dizzy, looking over my shoulder. I like speed. I can reduce 800 files to 20 and do all necessary post processing in under an hour. I've learned to be ruthless.
---------- Post added 01-27-19 at 12:24 PM ----------
Originally posted by Nunavut I prefer landscapes, although as of late - home portraits (have a 3 month old baby). Low light is a problem inside, and although I have a flash setup with cactus v6ii and tripods, I often don't have time to set a scene up; so am shooting the 77 handheld at high iso.
Hiking and travel is a regular pursuit for landscape, so I travel with the 20-40 as general purpose (which I love).
A long time ago I did wide angle, but haven't used my 10-20 in many years.
Lastly, I photograph indoor macro (lego believe it or not!) but on a tripod with controlled light sources.
Thanks for everyone's opinions. Still haven't purchased the camera.
The K-1 is a better landscape camera, with it's extended DR and low light capability. Your 77 will work marvellously on a K-1.
Th K-P frame rate and cleaned up accelerator chip files are a great answer to K-1 high ISO files.
If you like the 20-40 on a K-3 the 28-105 on the K-1 will be a pretty big improvement in terms of flexibility.
But overall, I'd stick with a K-P. You know the lenses on that body. You're used to shooting APS-c. A K-1 is a whole new learning curve. KP files stack up pretty well against K-1 files for low light, with the added depth of field at the same exposure values likely to get you better images, overall. For macro, it's a toss up. If that was the only thing, I'd probably go with the K-1.
But the frame rate is enough better on the K-P, I'd definitely go with that for kid shots unless they are sitting still.
