02-07-2019, 01:29 AM   #16
QuoteOriginally posted by sundown Quote
The New Panasonic S1R, being 47 MP, will have a 4:3 crop, which I find quite interesting and 47Mps should be fine when you crop.
Can I mount my 6 pentax lenses on the S1R?
---------- Post added 07-02-19 at 09:30 ----------
QuoteOriginally posted by kypfer Quote
The 3:2 and 4:3 ratios are very historical, they reflect the "half-plate" and "quarter-plate" sizes of glass plates and cut film from before the days of roll-film.
Thanks for this insight. Very interesting. As of today, I'd be more interested in the composition side of things.
02-07-2019, 01:37 AM   #17
Yes, you can, with adapters and at a cost of loss of functionality
02-07-2019, 02:39 AM - 1 Like   #18
MJKoski's Avatar
3:2 is indeed bad format. It is not wide enough for panoramic shots or tall enough to get tall forest/mountain/architecture scenes in one shot with moderate-to-normal wide angle lenses. 5:4 or 1:1 is the proper format. 150mm lens ('normal') mounted on my 4x5" camera feels like a moderate wide angle compared to crippled and boring 50mm 3:2 FF format.
02-07-2019, 03:50 AM   #19
Probably the issue is primarily historical in that 35mm cameras had 3:2 ratios. At this point, I suppose Pentax could call Sony up and ask them for a different crop, but they would probably pay more for that sensor as it wouldn't be one that was just available off the shelf.
The most likely solution is that future cameras will add additional crops that can be highlighted in the viewfinder.
At the same time, we do have it easy now and it isn't that hard to do a little crop in Lightroom to get the aspect ratio you want, provided you shoot wide enough to begin with.
02-07-2019, 05:51 AM - 1 Like   #20
UncleVanya's Avatar
@biz-engineer
The crop marking comments made by photoptimist were that it would be nice if the other ratios were there. It was easy to misread.
You aren't missing out on an obscure feature, it isn't there.
02-07-2019, 06:19 AM   #21
QuoteOriginally posted by MJKoski Quote
Well, 5:4 is best for vertical shots, but not so much for panoramic shots. So ideally, two cameras with two different aspects ratios are needed: one best suited for panos and one for vertical shots. 3:2 is neither of them but good as single camera compromise. Of course you could take advantage of a 5:4 sensor for single vertical or horizontal shots, and pan it horizontally for landscape panorama. Two different ways of looking at it.
02-07-2019, 07:03 AM - 1 Like   #22
photoptimist's Avatar
@biz-engineer
Exactly! Currently the camera only has crop modes and OVF frame lines for FF, APS-C, and 1:1. I'd like more.
P.S. I edited my post to clarify the current versus wished-for functionality.
02-07-2019, 07:29 AM   #23
MJKoski's Avatar
I remember Canon 1Ds3 had a good amount of crop markings to select from. Even exotic 6:7 ratio. They would be shown in viewfinder then.
02-07-2019, 08:39 AM   #24
At least, cropped frames in live view doesn't look so hard to implement. There are 4 possible grip select-able in the K1, but I haven't been able how to make use of them. I tried to figure what Pentax engineers have been thinking when they implemented those grids but I failed.
02-07-2019, 09:34 AM - 1 Like   #25
And if you had a 4:3 camera you'd want a 3:2. I shoot all kinds of aspect ratios as you can see in my signature. 1:1, 5:4 (the actual ratio on a Pentax 6x7), 3:2 and 3:1. One thing I've discovered is you can shoot 4:3 and 5:4 with your digital camera that is 3:2. That's right, you can crop. And you don't need to actually see the scene in 4:3 to shoot those compositions. You can train your eye to see a more square compositions in a wider frame. I reach for my 6x9 over my 6x7 more often because of the aspect ratio. YMMV of course.
02-07-2019, 10:00 AM   #26
Wheatfield's Avatar
QuoteOriginally posted by Leumas Quote
I've come to realize that 3:2 is a terrible ratio for most things for me. For almost everything from landscape to portraiture I find myself cropping to a 4:3 or 5:4 ratio. 3:2 is just not very pleasing to the eye from a composition standpoint.
As such I really hope they decide to release a native FF sensor in either 4:3 or 5:4. This would provide a much higher and usable resolution in many cases.
Anyone else desire such a thing?
Nope. Iíve learned to crop my images to fit the final purpose.
Also, you are wrong about a 4:3 or 5:4 sensor providing higher usable resolution.
02-07-2019, 10:06 AM   #27
normhead's Avatar
When I want 4x5 or 3x4 or a custom crop I just make it that way. These days, producing slide shows for my 19:9 TV, almost everything I do is cropped to 16:9, and the surprise is, especially with landscapes, many image look better that way.
Modern sensors are such high resolution, just crop for what you want. What's the issue?
---------- Post added 02-07-19 at 12:08 PM ----------
And why would folks put up with those restrictions if they don't have to?
02-07-2019, 11:15 AM   #28
How to you adjust the photographic view point relative to 5:4 or 4:3 frame diagonal?
How do you crop the 3:2 frame to 4:3 when making composition hors-champs (or hors-cadre)?
Something to learn here?
02-07-2019, 11:54 AM - 2 Likes   #29
I do it like this. When I see a scene that would look great in say another aspect than the camera is shooting, I frame it accordingly so when I crop 1:1 as in this example it comes out like I expect. And I even get a little wiggle room for framing the composition.
So if I had to have a 1:1 camera to take this picture what should I do? Should I stand there and curse myself for not bring along another camera? Should I consider running home and get one and come back? Do I say f* it I'm screwed I can't take this picture? And also do I say, crap, I don't have a BW sensor camera either. What do I do now?
An ideal sensor would be round, I think.
02-07-2019, 12:01 PM   #30
You mean you rotate the image prior to cropping?
For the 1:1, no issue at all, the K1 has 1:1 frame available in ovf and live view. The difficulty I have is if I want a 5:4 ratio and have the image framed in relation to the diagonal of the frame? How do I do it with a 3:2 frame?
35mm, aspect, camera, composition, crop, dslr, ff, film, format, frame, landscape, marks, pentax, photography, portrait, prints, ratio, resolution, roll, round, screen, sensor, view
Sensor Dust or No Sensor Dust? DavidSKAF3 Troubleshooting and Beginner Help 16 09-07-2018 04:18 PM
K50 Sensor Stuck in 16 to the left. Sensor shakes when attempting to correct PhotoGaffer Pentax K-30 & K-50 7 06-27-2018 01:05 AM
I wish there was a Pentax K1000 with digital sensor :) spystyle Troubleshooting and Beginner Help 54 07-30-2009 01:36 PM
K-7 sensor vs K20d sensor Mystic Pentax News and Rumors 33 06-21-2009 03:01 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
All times are GMT -7. The time now is 01:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
