02-13-2019, 08:21 AM   #1
Cable switch terminal Pentax K10D
Just bought a Miops Mobile Dongle Kit. Connected it and it worked. But now it doesn’t. It seems as if the inside part (in the camera) is loose and dislocated. Can if fix it? Is it doable? I guess I got to pick it apart. Where can I find a description of how to do it?
02-13-2019, 09:36 AM   #2
Not a Number's Avatar
Do you mean the input jack for the cable remote? It should be a 2.5mm stereo jack. You should be able to find an off the shelf replacement. Tear down of the camera to get to the part is probably extensive involving a lot of un-soldering and re-soldering wires. Depends of if you have the tools and skills to do the job. An incomplete copy of the K10D service manual can be downloaded from the pentax-hack.info website. Missing is the section on the top plate and the parts, wiring and exploded diagrams. Part of the exploded diagram can be found but it is incomplete.
02-13-2019, 07:49 PM   #3
Thank you. Yes the input jack. Sounds as way over my head. But I might give it a try.
02-13-2019, 09:52 PM   #4
I suspect it could be a little tricky, not tooo bad if you are used to fixing electronics.
In the IR conversion instructions following you can see a partial disassembly.
Pentax K10D Infrared Conversion DIY Tutorial and Disassembly Guide - Kolari Vision
02-14-2019, 11:55 AM   #5
QuoteOriginally posted by sqrrl Quote
Nice guide. You can see the jack on the PCB in this picture at the lower left. The picture above this one on the blog page shows which wires you need to disconnect.
Pretty much an off the shelf surface mount 2.5mm stereo input jack. You might just need to shove a paperclip in the opposite end to reseat the contacts.
02-15-2019, 12:25 AM   #6
Thank you so much!
02-15-2019, 12:33 AM   #7
Thank you. What a great forum this is. Bought a secondhand K70 yesterday. But I will fix the k10d and use it for time lapse.
cable switch, switch terminal pentax
Cable Release Terminal JKoch Pentax K-5 9 04-04-2018 10:07 AM
Cable Switch Conversion for K10D jonhock Do-It-Yourself 4 09-19-2010 09:23 AM
For Sale - Sold: Pentax Cable Switch 205 for K10D, 20D, K-7, etc jbcampbell Sold Items 2 09-08-2009 09:16 AM
Cable switch terminal Confused Pentax DSLR Discussion 6 07-21-2007 09:00 AM
All times are GMT -7. The time now is 12:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
