Originally posted by cpk Before I wrote my preceding response about how to do the auto-tagging in Lightroom, I went into the software and did the auto-tagging of two photo shoots where I had traveled some distance in each case, one in the city and the other in the country. I did this because I had not done this procedure in a long time and wanted to make sure I described it correctly. I had a hell of a time figuring it out. Why? Mainly because I hadn't done it in so long, but in one case I had your problem because it was around the time daylight savings time came into effect and I hadn't adjusted my camera's time. The times in the cell phone and the camera were out of sync. There is an adjustment in the Map/Tracklog menu called Set Time Zone Offset...; I had to adjust this by one hour to fix the problem. I suspect this may be your problem too.
You are right I set the time offset and made sure the times on the phone and camera were synced and it worked like a charm. Thanks for the help
