10-03-2008, 05:45 PM   #16
add Exposure Compensation
10-03-2008, 06:56 PM   #17
heatherslightbox's Avatar
I tried mounting the rest of my lenses on the K200 and I noticed with my heavier lenses (28-75, especially) that the camera/lens becomes front-heavy, which isn't an issue with the K10. I'll just have to make a special point that when using the K200 to better balance the lens in my left hand to shoot. I could simply get a grip for the K200, but the K200 is supposed to be my lighter weight second body. I'm seriously considering getting the DA16-45 to be the walkaround lens for the K200, once my LBA challenge is over.
Heather
10-03-2008, 07:20 PM   #18
QuoteOriginally posted by hotrod Quote
So what do you do about the underexposure?
I can, perhaps, lend a hand here. CameraLabs is right... the camera does technically underexpose in most conditions. However, it depends on what you're shooting as to wether or not it's something that concerns you. As an example, I was shooting the picture below because of the sky/rock contrast. The lighter picture is with exposure compensation +1. It was shot in manual, and I upped the shutter speed to achieve the effect.
To me, the darker one looks better. The colors are more natural, and it WAS in fact that dark out. Technically speaking it's not as bright or vivid, but that's what was there. The bright one, to me, looks almost as if the sun was shining down on that rock, which it certainly was not. Please excuse the fact that the pictures are not identically framed... didn't have a tripod. Suffice it to say, the K200D takes very realistic looking pictures without tweaking it. That's my take on it anyways. The brighter picture is better exposed from an EV standpoint, but I don't think it looks better than the bottom one.
PENTAX K200D  Photo
PENTAX K200D  Photo
10-03-2008, 09:04 PM   #19
Marc Sabatella's Avatar
There is no underexposure if you understand how to use a DSLR metering system. Point at a 18% gray target and you get a picture with 12-13% reflectance, just like the ISO standards say you should. If you understand this, and how to use the camera's controls to alter the default exposure and why and when this would ne necessary, you can get the exposure you want, every time, without fail.
10-03-2008, 09:10 PM   #20
Canada_Rockies's Avatar
I do nothing. I like Mr. Pentax's supposed underexposure - it's less than a stop according to all the testers, and I guess that I grew used to it over the years. With slide film I did not have to trick the ASA/ISO to expose properly. Maybe I have an unusual k10d, but it's metering seems to be pretty good.
There are situations that fool meters. Hockey rinks are one, dark shaded forested areas are another.
10-04-2008, 02:49 AM   #21
Most of the time, I don' t have a problem with underexposure either. If I'm concerned that it might be an issue, then I'll simply bracket. Knowing the fundmentals of exposure helps in being able to use the manual setting to override whatever the camera may be telling you. If all else fails, then shoot in RAW and fix whatever problems crop up in PP.
Heather
10-04-2008, 04:25 AM   #22
My feeling as well.
It's not something you "notice". It's a natural occurence, and if you work from 'feeling' the image or from the histogram, then you always expose perfectly, so you don't 'realize' this effect.
10-04-2008, 08:06 AM   #23
hotrod's Avatar
I asked that question because i have a canon XTI which of course has underexposure problem and it's realy annoying. At the canon forums everybody says it's user error and not the camera, which of course everybody knows itīs a camera problem . You guys admit that it does subexpose which i think is not a problem but that pentax likes it that way.
Getting rid of my canon stuff by the start of next year to get the k200d or the k20d and a good da*16-50 lens.
10-04-2008, 08:44 AM   #24
Clicker's Avatar
It's my understanding all digital cameras default to "under-exposure", in any auto/preset mode.
10-04-2008, 09:11 AM   #25
QuoteOriginally posted by drewdlephone Quote
if you like the darker photo, then that's the better picture for you. however i downloaded both photos to check the histograms and the second histogram is underexposed meaning you're losing a tonne of shadow detail. if it were me, i'd rather take the better exposed photo then make it darker in PP.
so you're saying every camera can meter a grey card on spot meter perfectly. great, but it's not practical to use a grey card most of the time. in the end it's about learning to use the camera to remember when it over / under exposes
it is my understanding the underexposure is done to protect the highlights
on a side but related note,
if you shoot raw, the best way is to expose using the Expose Right method. the camera is more sensitive to brighter exposures and therefore expose your histogram all the way to the right but not touching. then when you decrease the exposure in PP, you don't more detail and less noise. sometimes this has involved me going to +2 EV. again this takes practice to get right
10-04-2008, 09:28 AM   #26
jgredline's Avatar
QuoteOriginally posted by k100d Quote
10-04-2008, 10:14 AM   #27
hotrod's Avatar
QuoteOriginally posted by Clicker Quote
Canon XTI also underexposes in manual mode.
10-04-2008, 10:34 AM   #28
jgredline's Avatar
My wife shoots a Nikon D40 and my Daughter shoots a Nikon D200 and D300 and they under expose as well..
10-04-2008, 12:17 PM   #29
FHPhotographer's Avatar
Upgrade to K200?
I can't speak for her, but I personally was willing to accept those things in order to gain the smaller/lighter body, more comfortable (for me) grip, AA batteries, quieter shutter, allegedly better high ISO performance including no VPN (even though it's the same sensor, it's the ADC and other elements of the pipeline differ), and the higher likelihood for firmware upgrades.
I'm interested if there is enough "extra" in the K200 to justify a move up from the K100 other than a 40% larger sensor that has denser photosites? I've compared them online, but I am curious how folks who have used them both say the K200 feels compared to the K100 and how it affects picture taking,
FHPhotographer
10-04-2008, 02:17 PM   #30
QuoteOriginally posted by FHPhotographer Quote
FHPhotographer
read khardur's review
https://www.pentaxforums.com/forums/pentax-dslr-discussion/22916-k200d-review.html
af, buttons, camera, dslr, grip, impressions, k10, photography, time
My K-5 First Impressions deadwolfbones Pentax K-5 & K-5 II 53 10-29-2010 07:31 PM
K20 impressions (switching from K200D) kristoffon Pentax DSLR Discussion 70 07-07-2009 07:09 AM
Initial impressions of the K200D dugrant153 Pentax DSLR Discussion 0 01-11-2009 02:24 AM
K200d First Impressions and Snaps riotsquad Pentax DSLR Discussion 1 05-19-2008 01:47 PM
K200D First Impressions RiceHigh Pentax DSLR Discussion 72 03-29-2008 12:56 PM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
