Originally posted by Tracy68 Any information would be appreciated - is this common? Is it fixable?
Welcome to the Pentax Forums!
It is likely that your camera has an aperture control failure where the lens aperture is stopping down all the way rather than to the opening set by the meter. The common cause is due to a defective solenoid in something called the Diaphragm Control Block (aka Aperture Control Block) in the camera body.
This sort of problem is not uncommon in K-30 and K-50 models and is fixable. I believe the cost through the Pentax-authorized repair facility (Precision Camera Repair in Connecticut) is under $200*. Claims that Precision will replace the defective piece with a similar defective part are unfounded, at least in regards to those I know who have had the repair done and are happy to report that the repair is still good, four years or more later.
Alternatively, there are various other shops that advertise a fix for about $100 or less, though most are unwilling to said how it is done. Current consensus is that used parts from other model cameras are being used since the so-called "white made-in-Japan" solenoids are reportedly no longer available. If all the above sounds rumor-based and rather sketchy, that is because information on Internet forums is often so. I write that in full respect for those (particularly a tenacious group in Germany) who have worked this issue extensively through many false leads and much speculation to end up with a plausible cause and remedy.
Given that you are not that fond of the camera, the most reasonable path might be to take the money that might have been applied towards a repair and use it to purchase something that is more to your liking.
(...went through the repair process with Precision in 2015 and am happy with the result...)
* The figure I remember for the repair through Precision was $149, but don't hold me to it.
