I had seen these on Wiki - not sure if it is accurate. It did also talk about the speed of connection and the lack of a need for pairing for NFC. My only use of NFC on Panasonic was with control over the device - typically I used Wifi direct.
Bluetooth comparison
Aspect NFC Bluetooth Bluetooth Low Energy
Tag requires power No Yes Yes
Cost of tag US$0.10 US$5.00 US$5.00
RFID compatible ISO 18000-3 Active Active
Standardisation body ISO/IEC Bluetooth SIG Bluetooth SIG
Network standard ISO 13157 etc. IEEE 802.15.1 (no longer maintained) IEEE 802.15.1 (no longer maintained)
Network type Point-to-point WPAN WPAN
Cryptography Not with RFID Available Available
Range < 20 cm ≈100 m (class 1) ≈50 m
Frequency 13.56 MHz 2.4–2.5 GHz 2.4–2.5 GHz
Bit rate 424 kbit/s 2.1 Mbit/s 1 Mbit/s
Set-up time < 0.1 s < 6 s < 0.006 s
Current consumption < 15 mA (read) Varies with class < 15 mA (read and transmit)
From here:
https://en.wikipedia.org/wiki/Near-field_communication
