10-04-2008, 11:49 AM   #1
Help with Pentax K100D
HI.
I have a pentax K100D and have a problem i hope you guys can help me with...
when i turn camera on AV - - are flashing in top of screen on camera where the battery indicator is, and i cant take any pictures !
Can anyone help me in telling me HOW TO GET THAT OFF AND TAKE SOME PICTURES?
Thanks for any help..
Colin ( Pentax K100D Newbie )
10-04-2008, 12:03 PM   #2
FHPhotographer's Avatar
battery light...
QuoteOriginally posted by kartman_uk Quote
HI.
You're talking about the top LCD panel and not the back screen, right? The battery blinks on the top LCD panel in the K100D when it's depleted then turns itself off. If you haven't replaced the batteries, do so; you might have one that's bad for some reason so replace them all. If that doesn't help, make sure you don't have something in the battery compartment that's shorting one of the contacts. If not that, I can't think of anything else, it may need to go in to the shop unless somebody else on the Forum has a solution. Good luck,
FHPhotographer
10-04-2008, 12:07 PM   #3
Its not that..
It is on the TOP LCD screen...
BUT its above the battery warning..... ITS got AV - - Flashing ! I dont know what else to do to get to take photos....
Thanks
Colin ( Pentax Newbie )
10-04-2008, 02:25 PM   #4
I am having the same problem, as I type this, on the same camera.
I just bought a new set of Duracell AA's today and and they are charging now.
Hope it works.
I had the best luck with Duracell in the past.
Will let you know tomorrow if all goes well.
10-04-2008, 02:32 PM   #5
Marc Sabatella's Avatar
Do you perhaps have an old manual aperture lens mounted (or a more modern lens but with its aperture ring not set to "A") and don't have the "Using aperture ring" set to permitted in the custom menu?
10-04-2008, 07:52 PM   #6
Solved the problem thanks to Marc Sabatella.
Changed the batteries for newly recharged ones and still got the AV---.
Changed my lens from a 70-300 to a 18-55 and the 18-55 worked (no AV---).
Changed back to the 70-300 and the AV--- appeared agin.
Used marcs suggestion and located the "A"button and reset it and I am up and running again.
Thanks Marc
camera, dslr, k100d, pentax, photography, pictures
For Sale - Sold: Pentax K100D Super with upgraded Pentax DA 18-55mm f/3.5-5.6 AL II lens + SMC ravinj Sold Items 6 05-27-2010 06:50 PM
For Sale - Sold: Pentax K100D, Kenko 2x Macro Teleplus MC7, Pentax Pz-1, Pentax AF500 Flash hinman Sold Items 28 09-25-2008 10:46 AM
Pentax K100d or K100D Super, which one? Jimsi777 General Talk 5 10-01-2007 03:32 PM
Pentax K100D or K100D Super? Confused Pentax DSLR Discussion 5 07-06-2007 09:54 PM
All times are GMT -7. The time now is 09:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
