04-15-2019, 05:35 PM   #1
K5IIs under exposes
Ir seems to be a problem in a lot of situations. These shots were taken with the around noon with the sun behind me.
PENTAX K-5 II s  Photo
04-15-2019, 05:48 PM   #2
bkpix's Avatar
Yes, from the EXIF as well as the image, that's underexposed. Might you have bumped the exposure compensation?
04-15-2019, 06:10 PM   #3
QuoteOriginally posted by bkpix Quote
I don't believe so. I will have to test further to make sure
04-15-2019, 06:10 PM   #4
photoptimist's Avatar
Besides accidental EC, another common cause is the AE meter set to "spot." (In these two images, the meter would seen just the sky and exposed the image just for that.)
04-15-2019, 06:16 PM   #5
I had it set to center weighted
04-15-2019, 06:26 PM   #6
QuoteOriginally posted by robert Quote
Any reason you're not using matrix metering in a situation like this? In any case, since the center isn't the brightest in this shot, it's a little weird that it turned out so dark.
04-15-2019, 08:03 PM   #7
pschlute's Avatar
Were you using a tripod ?
04-15-2019, 08:10 PM   #8
bkpix's Avatar
I believe the EXIF will show whether exposure compensation was activated if you delve deep enough into the file.
04-15-2019, 08:16 PM   #9
Otis Memorial Pentaxian
High noon
Sunny day
Significant sky
Center weighted
Light clouds and/or white walls in the center 2/3rd of the frame
f/8, 1/1000s, ISO 100
Sunny 16 would indicate the same, but 1/500s so the exposure is close...only 1 stop under if going that route. A chimp of histogram looks to have indicated about 2 stops under in the field and possible even 2.5-3.0 stops to bring up the values of the barn and clouds, though either of those could have been addressed in PP.
This looks to be reasonable performance for center-weighted metering based on the contents of the scene.
04-15-2019, 08:20 PM   #10
No EC according to the EXIF. This appears to be the classic wide-angle landscape trap where the meter gets fooled by sky. I suspect the images could have been salvaged from the RAW in PP.
04-15-2019, 08:21 PM - 2 Likes   #11
Brilliant! The next question is whether the eyepiece was open to direct sun. If so, that is the smoking gun.
Note: Not to diminish the fact of the obvious underexposure of the photos in the original post or the possibility that the camera meter might be failing.
04-16-2019, 11:45 AM   #12
K5IIs under exposes.It seems to be a problem in a lot of situations.
I was having the same problem when I got my new (to me) K-5 IIs recently. Different compositions, lighting situations, etc. Switched to matrix metering and the problem went away.
04-17-2019, 12:31 PM   #13
I can see no particular reason for these scenes to be shot using center-weighted metering. The default matrix metering should be fine. That said, the K-5 series does tend to slightly under expose, I'd say about 1/3 stop or so, which is not always noticeable. But the examples shown here are way off from that.
And yes, stray light entering through the VF eyepiece can wreak havoc on exposure!
The K-5 IIs is a great camera.
04-17-2019, 09:44 PM   #14
Center weighted metering with the majority of the center being sky......no mystery here I would say.
Evaluative/Matrix metering is designed for scenes like this.
It would be interesting to shoot the same scenes again with matrix metering then spot metering for the grass. Then review the results.
04-22-2019, 04:27 PM   #15
Wheatfield's Avatar
It’s definitely preserving the highlights. Does your camera do this with every lens or just with the 21?
camera, dslr, photography
K5IIs randomly over and under exposes now and then TroutHunterJohn Pentax K-5 & K-5 II 7 06-07-2015 01:29 AM
Sigma EM 140 on K-3 over exposes derekkite Flashes, Lighting, and Studio 3 05-07-2014 02:31 AM
k-x way under exposes on start up ziscwg Troubleshooting and Beginner Help 5 06-25-2013 06:23 PM
K5 only exposes correctly in auto GadgetFan Pentax K-5 & K-5 II 24 05-18-2013 08:03 PM
Lance Armstrong doping campaign exposes USADA’s hypocrisy jogiba General Talk 19 08-27-2012 07:08 AM
All times are GMT -7. The time now is 06:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
