Originally posted by Dartmoor Dave I'm just glad that this is a forum for photographers rather than hi-fi nuts. My dealings in classical vinyl bring me into contact with audiophiles quite often, and here's some of the things that many of those guys genuinely believe:
A £500 high-end mains cable will also make your music sound better, by working some sort of voodoo magic on the electricity after it has travelled hundreds of miles down the power lines to your house. In which case, I guess I should be charging my camera's batteries with an adapter using hand-drawn silver cable with gold-plated contacts. Yeah, right.
Ah. . . it felt good to get that off my chest.
Yes, audiophilia nervosa is a very real phenomenon, in no small part because the psychology of hearing isn't fully understood. You plunk down a lot of cash on something that looks impressive, is well made, and has some plausible sounding explanation of why it makes your hi fi sound way better ... and you want to believe in it (in part because you don't want to waste money) and so your ears do indeed hear something different, maybe better, than you had before.
And yet, that darn thick and expensive cable that connects my CD player to the wall does indeed have a very real, not subtle effect on my sound system. I've yet to see a voodoo-free explanation of why it is a better upgrade to my CD player than any other hi fi tweak out there. I've played a track for an unsuspecting listener, swapped the cables, and played it again. They ask "what did you do?" after noticing a clear upgrade to the sound. The fancy cable has no effect on my amplifier, I might point out. It only seems to be an upgrade to a digital device .... which has led me to wonder if indeed there are ways to tweak digital devices such as scanners or monitors via audiophile methods. I have to say, I've never tried them
But yes, bits are bits, and bytes are bytes, no matter how they're stored or transported. So long as your memory card can keep up with your camera, and is reliable (stay away from no-name house-brand cards, and stuff bought cause it was "great deal") you should be okay.
What the audiophiles have taught us, however, is that while digital data is robust and can be copied perfectly again and again, its conversion back to the analog realm is a delicate process, and can be affected by any number of small things (or big thick cables).
