04-25-2019, 01:02 PM   #16
Wasp's Avatar
There is not enough detail on the trees. A full strength HDR shot would have had that. So my guess is that it is possible to replicate this in one shot. I'm not knocking the K5 but a more modern sensor would be of some help in this regard.
04-25-2019, 03:53 PM   #17
I have had success pulling details out of the shadows in Raw shots from my K-5 like this. I do two different exposures in Camera Raw and then blend in Photoshop.
I have had good luck using HDR to shoot through windows from a dark inside to a sunny outside. I have not tried it for sunsets.
04-25-2019, 04:18 PM - 1 Like   #18
QuoteOriginally posted by Wasp Quote
I didn't want more details on the tress. The K5s dynamic range is higher than the newer models except for the full frame K1
---------- Post added 04-25-19 at 07:19 PM ----------
Yeah, the trees in the background and the one in the front are basically silhouettes, Robert.
When all's said and done, you've exposed for the sky.
Thats the way I wanted it lol I could have shown more details in the trees but didn't like it as well
04-25-2019, 04:30 PM   #19
Actually, the silhouette effect is nice, especially with the tree. To open shadows some, the easiest way would be using a grad ND filter for the shot, about a 2-stop would be effective, yet still providing some silhouetting. Your bracketing technique simply was not extreme enough- you needed to bracket a wider range of exposure. My KP, and probably other current models, has a 3-shot bracketed setting via a dial setting, adjustable as to the exposure degree. I have found it to be very effective.
You could try a bit of "fill-flash effect in photoshop to see what that brings.
04-25-2019, 04:38 PM   #20
clackers's Avatar
QuoteOriginally posted by robert Quote
Okay, but then this is not a good example to demonstrate your question, Robert, since HDR isn't needed to generate a silhouette.
04-25-2019, 04:46 PM   #21
normhead's Avatar
QuoteOriginally posted by Bunch Quote
Nah, Mossy Oaks, that didn't turn out bad at all. The way the trees are silhouetted in your photo make a much more interesting photo than just the washed out trees in Norm's photo that are supposedly more properly exposed.
If you decide you don't like the "washed out" trees, you can always make them black as in the original image. But if you like "washed out" you can do it with a better exposure. I'm not sure you know what "washed out" means, I'm not sure you're using it correctly.
04-26-2019, 09:55 AM   #22
In reply to the OP, the answer is Yes.
I could probably get it with my Samsung S7 phone
Expose for the sky and obviously shoot in RAW, then pull up the shadows in Lightroom/etc.
04-26-2019, 10:35 AM   #23
Darktable's LP filter can recover details from dark areas. First meter the photo to brightest spot and then apply following LPF technique. Important parameter is contrast, it should be -ve. This brightens dull areas and dims bright areas.
Using lowpass filter to recover shadows | darktable
camera, details, dslr, photography, shot, trees
Help with what can be achieved with Jpeg processing Flanoman Digital Processing, Software, and Printing 13 03-19-2019 05:43 PM
Maximum sharpness achieved? or lens not capable haroon88 Troubleshooting and Beginner Help 11 11-20-2017 02:12 AM
People Could have been the whiskey ...might have.. daacon Post Your Photos! 12 02-03-2012 07:05 AM
I Have Achieved Critical Mass Mike Cash Pentax Film SLR Discussion 14 03-22-2008 04:16 AM
I have achieved sharpness Tom Brown Pentax DSLR Discussion 21 03-30-2007 08:34 PM
All times are GMT -7. The time now is 05:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
