Hi Andrea K,
First... thank you for this app... it's
aewsome!
I was able to connect via the K-1 Wifi and download the content of a corrupt SD card onto my Windows 10 laptop...
Actually, the need was : My daughter had taken photos with her K-5 ecently, and suddently, the SD card she was using couldn't be read by any computer, but images were visible on the K-5.
I tried that corrupted SD Card on my K-1 (with the "read-only" switch on to prevent any new data to be written) and photos were still visible/accessible...
So, I had in idea to use the K-1
wifi connexion on my laptop to download those images, not being sure if what I saw on the K-1 display screen were only "jpeg previews" stored in the actual RAW Files, or the good copies of those files (DNG format)...
Anyways,
I was a bit shocked when I discovered that Ricoh/Pentax did not had any Windows OS apps... so after searching a bit on PF about Wifi connexions, I was pleased to find your app...
At the end, connextion and downloads saved saved my daughter's life** (sort of...
Anyways, thanks for that!
Originally posted by Craigbob I encountered quite a few crashes where the program would just close on it's own.
Originally posted by Andrea K About 1 and 2: I need some screenshots with the errors and the Log that you can download through the app in the Options section.
However, one of the goals of this reply is also to report the
same issue as for @Craigbob
Symptoms: everytime I am willing to close your app, it would hang, and UI stays there... It never terminate. I am getting those "
Wifi Commander for Pentax is not responding" error messages.
The "Close the program" or "Wait for the program to respond" options wouldn't work.
I have to reboot my entire computer to clear the app... it wouldn't close otherwise (even if I use the Windows 10 Task Manager to kill the process).
I search a bit on your web page where I should send the debugging info, but couln't figure out...
Some infos:
Windows 10, Build 18362.476
Dell Precision 7520 wit i7-7920HQ CPU , 32Gb RAM, plenty of HD space on SSD 2TB...
(let me know what other info would be required)
so if you have an email, please provide in PM, and I'll forward screenshots and/or logs... (or advise otherwise if I missed what to do in those cases...)
**My daughter will for sure make a donation for this...
