Originally posted by GUB That totally depends on the image
It really depends on your WB for this image it looks like you are using daylight WB so your red channel is being multiplied by a factor of 2 stops an I suspect this is why your reds are so far to the right
---------- Post added 05-22-2019 at 11:43 PM ----------
Originally posted by GUB I had to pull the exposure back half a stop (see EV in settings) to get the histogram within the margins but no, it does not appear to be clipped. But it is clear the red will clip first here.
Again its more than likely the raw converter that is what you think is clipping the reds because of how WB works, as for the exposure clipping the raw data its more than likely that its at least underexposed by the WB and for daylight WB that would be around 1 to 2 stops
