Originally posted by MarkJerling The whole shake reduction system is quite a bit larger than in the K3, so, it has more inertia when moving around.
More importantly - Enjoy your new camera!
yes, that was coming to my mind as well, thanks bro!
---------- Post added 07-03-19 at 04:07 AM ----------
Originally posted by Lowell Goudge When it is inactive there should be no movement at all, because the actuators should hold the sensor perfectly still.
When off, you need to consider that the K1 sensor is more than double the area of the K3 and likely more. Than double the mass.
It is the movement, and stopping of the mass that you feel
When on, I feel sensor movement when I quickly changing orientation but it's absolutely same as in K3, just bigger sensor means you feel it more. No feel at all when in video mode either K3 or K1.
Anyway, I think I'm getting used to it... now when I'm comparing them side by side they both behave same way, just I need to consider that the K1 is much bigger as you guys perfectly mentioned. Thanks!
