I take the used sd card and put it into the computer and immediately make a copy which I use for all pp
I then store it if I want to or format the used card in the camera or just put an unused card into the camera
sd cards are relatively cheap now a days
______________________
since I have the battery grips on my K 3 and K 3 II I have an extra sd card with my cameras at all times.
it only gets switched to the camera if I forget to put an sd card in when I switch out the used one or if I run out of memory in the field.
[ if you use the AA battery tray then there is no room to stash an extra sd card in the grip ]
_______________________
I always try to remember to check the battery and sd card status before leaving and if I am smart on that particular day, I bring a spare battery or two any way
_____________________________________
I try to remember Finnigan's corollary to Murphy's Law ( Murphy was an optimist ) and follow the 7Ps:
" The 7 Ps is a British Army adage for
Proper
Planning and
Preparation
Prevents
Piss
Poor
Performance. The 7 Ps are normally referred to as "the 7 Ps" rather than as an acronym: (i.e. PPPPPPP) " -
https://military.wikia.org/wiki/7_Ps_(military_adage)
please note that I said
I try to
