10-11-2008, 02:46 PM   #1
Is this dust on my K200D sensor?
There is a spec in my viewfinder in the same relative position as in my pictures, but I'm guessing that's just coincidence. I'm guessing this is a pesky dust spec on my sensor? I've tried the body dust removal but doesn't seem to be working. Would you buy a blower and try that?
10-11-2008, 02:51 PM   #2
kkoether's Avatar
I would think if you see it in the viewfinder and on the picture that it would be on the lens. Sensor dust would not be visible in the viewfinder.
10-11-2008, 02:52 PM   #3
I just checked. It's there no matter which lens I use. And in the same position.
10-11-2008, 02:57 PM   #4
kkoether's Avatar
It sounds like it may be dust on the sensor. I've not had to clean mine yet so I cannot offer any words of wisdom on cleaning it. Maybe someone with more experiance will jump in with the info you need.
10-11-2008, 02:58 PM   #5
I'm actually seeing two specs now. Must be sensor dust, huh?
10-11-2008, 03:03 PM   #6
looks like there are quite a few all round the image (small ones).
Get a giottos rocket blower. Completely sorted my k20d in seconds
10-11-2008, 04:39 PM   #7
Yeah, the Giotto Rocket Blower should be able to take care of that.
10-11-2008, 06:19 PM   #8
SpecialK's Avatar
Looks like yellow arrows to me. A rocket blower should handle those, and the gray blobs next to them.
10-11-2008, 07:47 PM   #9
MoiVous's Avatar
Have you tried the Dust Alert sensor test to confirm this before you play with the blowers etc?
Page 231 of the manual tells you how to do it...
  • Use a DA etc lens (needs auto aperture)
  • Leave the lens in AF mode
  • In the SetUp menu choose Dust Alert and press the -> on the 4 way control
  • Aim the camera at a clean white wall and release the shutter
  • Press Ok to view the dust
The pages after the Dust Alert tell you how to clean it
Hope you get rid of your dust problem....
10-12-2008, 08:19 AM   #10
QuoteOriginally posted by MoiVous Quote
Very much appreciated that. Just performed that function and sure enough those two specs turn up. Too much changing lenses yesterday under fall foliage trees, plus, the pollen count is unbelievably high (wife constantly sneezing - going to rename her Rudolf here soon).
Thanks.
10-12-2008, 09:06 AM   #11
tomtor's Avatar
Clearly dust. Dust spots get always smaller and sharper if you use a smaller aperture. Just test it at F16 or F22 by taking an image of the bright sky in manual focus and focussed at a small distance. All you should see is a grey/blue image with dust specks.
A good blower (the Giotto is good, it filters the air before blowing it into your camera) works fine in most cases (point the opening of the camera down when blowing so that the gravitation helps slightly getting the dust out instead of just moving it around.
A device called Arctic Butterfly is another option but a lot more expensive. Start with the blower. The advantage of the Arctic Butterfly is that dust is attracted by the brush instead of just moved.
10-21-2008, 04:48 PM   #12
Thanks for the tips. I got a Giotto off Ebay for $15, just used at Voila - no dust on the Dust Alert. Thanks for the recommendation.
camera, dslr, dust, photography, spec
Dust on Sensor yahmon Troubleshooting and Beginner Help 6 04-27-2010 03:58 PM
Sensor dust Pablom Troubleshooting and Beginner Help 24 04-10-2010 05:57 AM
dust on sensor or dust on lens 41ants Troubleshooting and Beginner Help 10 10-08-2009 10:28 AM
sensor dust(?), again tibbitts Pentax DSLR Discussion 1 10-02-2008 04:12 PM
dust behind sensor? jsundin Pentax DSLR Discussion 3 11-24-2006 09:51 AM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
