08-28-2019, 09:42 AM   #1
Sensor Shake/Cleaning
I've been looking to upgrading from my K-r, which I have had since 2010, specifically the K-70. One feature I've appreciated in the K-r is the sensor cleaning system. The Dust Alert allows me to see any dust which may have accumulated on the sensor, allowing activation of the sensor-shake mechanism, then reviewing the cleaned CMOS on a blank screen. However, this feature is absent on the K-70, the instructions recommending the use of a blower (of dry air, presumably), not touching the CMOS with a brush. The shutter-shake and visual pre and post checking feature has inexplicably disappeared from the K-S2, K-5II and IIa, K-30, K-50, K-70, KP and the FF K-1 II. Can anyone enlighten me why this is? Or is there some way of accessing that feature via some undocumented "back door" on those recent models?
Last edited by PENTAPSC; 08-28-2019 at 09:43 AM. Reason: Forgot to include the K-50 in my text
08-28-2019, 09:53 AM - 2 Likes   #2
A lot of those cameras have the sensor shake dust removal, just not the automatic review images.
The KP and some higher end models have an ultrasonic system that in my experience works significantly better.
Yeah, just confirmed that the K70 has sensor shake dust removal, if that was what you were concerned about.
08-28-2019, 10:06 AM - 1 Like   #3
jatrax's Avatar
Just set it to clean every time you turn on the camera. I have done that since the k-5 (maybe on the k-x as well). It works flawlessly and never need to worry or check for dust.
08-28-2019, 10:36 AM - 2 Likes   #4
TDLR, the original DR (Dust removal) system was noisy and less effective. DR II is almost completely silent and in use in current/high end bodies.
All Pentax cameras with SR have either DR or DR II.
08-28-2019, 11:33 AM   #5
Awesome! Thanks, guys!
08-29-2019, 05:50 AM   #6
Madaboutpix's Avatar
Yes, you can check for dust without extra help from the camera. Nonetheless, Dust Alert was a helpful and comfortable feature, and a brand differentiator to boot. In connection with the ultrasonic Dust Removal, it made the Pentax approach one of the most thorough in the industry. Please, Ricoh, can we have it back in the upcoming models, at least in the flagship ones? Glad my K-3 still has it.
08-29-2019, 08:38 AM   #7
SSGGeezer's Avatar
Shoot an image of a blue sky or white wall at a small aperture like f/22 and you will see if you actually need to do a sensor cleaning. Unless there is a lot of sticky stuff in the air when you are changing lenses, a blower will probably be all that is needed. I bought wet sensor cleaning swabs when I had my K-50 but haven't needed it with my KP or K-1 (Yet at least.)
camera, check image, cmos, dslr, dust, dust alert, feature, k-70, k-r, photography, sensor
K-30 sensor shake? Flying Kiwi Troubleshooting and Beginner Help 11 06-19-2018 08:42 AM
k 50 shake reduction shake jacques Visitors' Center 6 10-17-2017 11:07 AM
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 & K-5 II 3 06-14-2014 02:51 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
All times are GMT -7. The time now is 11:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
