09-02-2019, 02:40 AM   #1
CR-V3 Batteries in a K110D - which way up!!
Can't believe I have to ask such a daft question but I've only just bought a K110D and I'm worried I might damage it if I get it wrong. AA's are clearly marked as up or down but the CR's don't have top or bottom terminals. Help appreciated. Cheers
09-02-2019, 03:00 AM   #2
MarkJerling's Avatar
CR-V3 are always marked as to which terminal is a the + and which is the -. I was not aware that one can use CR-V3 batteries in a K110D.
The manual mentions that non-rechargeable CR-V3 batteries can be used, but the manual does not show how to insert those.
09-02-2019, 03:07 AM   #3
Not a Number's Avatar
All the photos of CR-V3 batteries I've looked at show a (+) marker on one of the terminals. Since the shape of the battery is "keyed" it can only go in one way with the positive (+) terminal in the right position. Without looking at the manual I would think the terminal end of the battery would go into the camera because the contacts on the door would just be a bridge or a single piece. You can check to see if there are no wires or strip connectors running from the camera body and door.
Download the manual here:
Pentax K110D - Downloads - RICOH IMAGING EUROPE S.A.S
Note: in the long run the most economical solution is to use rechargeable AA Ni-MH cells like Eneloops. If the camera eventually dies on you you can use the batteries in dozens of other devices.
09-02-2019, 04:11 AM   #4
Thanks for the replies folks didn't realise the batteries will only go in one way and also just noticed that deep inside the battery compartment is an illustration showing how to insert them!! Doh!!
Have bought some Eneloops as well but had already bought the CRV's so may as well use em up. Cheers.
09-02-2019, 10:42 AM - 1 Like   #5
microlight's Avatar
The CR-V3s should last months! I used to use them in my *ist DS.
camera, cr-v3 batteries, dslr, k110d, photography
For Sale - Sold: Sanyo CR-V3 batteries (US) DSims Sold Items 2 10-21-2010 02:44 PM
K-r can use CR-V3 and CS-205 cable ogl Pentax News and Rumors 4 09-10-2010 11:05 AM
K-x and CR-V3 batteries? retroflex Pentax DSLR Discussion 6 10-27-2009 12:49 AM
CR-V3 recharging JCSullivan General Talk 4 11-24-2007 11:51 AM
rechargeable CR-V3 k100d acrbill Pentax DSLR Discussion 14 11-10-2006 01:37 PM
All times are GMT -7. The time now is 11:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
