Originally posted by stillshot2
My K200D had a grip and was like new with about 3k shutter count, think I sold it about a year ago for $145 including shipping on feebay. I remember I once bought a K10D from KEH and sent it back because it had serious autofocus issues, but regardless was much bigger and heavier than the K200D which was amazingly comfortable to hold even without the grip attached.
Interesting. I rather feel the same way. Another factor that makes it good as a backup body is its use of widely-available AA batteries in case you've neglected to keep up with battery charging.
---------- Post added 01-26-20 at 06:26 PM ----------
Originally posted by volley
I doubt that you will see any difference in IQ between the K10 and K200. K10 has a better OVF (though I never had an issue with manual focus on my K200) but because of the grip I would keep the K200. I find the grip is the best I've ever used on a Pentax DSLR (and I've used K200/K5/K3/K1 all with grip).
From the day I received my K1 I have never used the K3 again. But the K200 still get regular use ...
Also interesting.
---------- Post added 01-26-20 at 06:27 PM ----------
Apparently, this issue has not been resolved yet. I never responded, despite having a K200D and a K20D (designed like the K10D but with updated features and controls). So here goes.
If you want a 3rd "beater" camera, as well as the AA battery backup, the K200D is a good candidate. For more casual work, but where you still want the control benefits of a DSLR, like social gatherings, etc. the K200D is lightweight, yet has WR, a top LCD, and as far as I know, never had the aperture block problem found in subsequent non-flagship models. Easy to take around with a compact lens, prime or zoom. I found Pentax DSLRs from this era tend to under-expose some, in this case around 1/2-2/3 stop. In many instances not a bad thing, and can also be easily compensated for. The K200D was designed after the K10D.
I found the K200D is very good for either indoor or fill-flash, even with the built-in unit. Does not tend to overdo and give such a "flashy" look. If just shooting JPEGs from the camera, its processing engine does a good job, better than tested reports of the K10D. Just be sure to implement "Fine Sharpening" in the Custom Image menus. Dpreview loved the K10D when it was tested, but found it was not a good JPEG shooter. JPEGs came out rather soft, and its in-camera sharpness adjustments were inadequate. So it essentially is designed for post processing.
The K200D's low light performance is not bad for the era, including its top ISO of 1600.
It has some other additional adjustment features, such as a highlight protection adjustment, in case of clipping.
The OP already has the K5 II with its full array of controls, 100% VF, many more updates, yet is more compact than the K10D, so letting the K10D go and keeping the K200D, which is even lighter than the K-5, to me makes more sense.
