10-09-2019, 06:04 AM   #16
For my K-1II I have been using theseamazon.com : Wasabi Power Battery for Pentax D-LI90 : Digital Camera Batteries : Camera & Photo?tag=pentaxforums-20& for about two years with no problems. They seem to be well made and appear to be nearly identical to OEM.
10-16-2019, 01:15 AM - 1 Like   #17
Progress report, the newmowas have been really good for a very cheap battery. Testing continues.....
10-16-2019, 10:12 AM   #18
QuoteOriginally posted by jeallen01 Quote
Tried various 3rd party batteries - most have been "medium" to "poor" in terms of capacity and life, and some (particularly D-Li109 versions) have even swelled so they won't fit into the camera body.
OTOH, I have found, over a couple of years or so, that the DSTE-branded D-Li90 and D-Li109 ones from an Amazon UK supplier seem to have pretty good capacity and last quite well, with no problems so far. Therefore those are what I would recommend if you can't run to the cost of the genuine Pentax versions.
Update on the above:
Whilst I am still very happy with the performance & life of the DSTE-brande D-Li90 batteries, I took recently one of their D-Li109 clones (bought only a year or two ago) to use in the K-70 on holiday and found that it now has a very short life - not as good as a 2012-dated Pentax original, and far worse than the 2018-dated Pentax battery that came with the K-70.
I also have another DSTE D-Li109 clone, bought with the first one, and I now need to check out how well that is faring, but I won't be surprised if it is in relatively poor condition!
10-19-2019, 11:44 PM   #19
I bought which I believe fake Pentax batteries on eBay. I think they won't last that long. May I know where to order Wasabi batteries? Thanks
10-20-2019, 12:36 AM   #20
QuoteOriginally posted by totsmuyco Quote
I can't get wasabi in the UK. Try amazon? Other good makes include hahnel, duracel, Watson. I got some cheap ones called Newmowa, they seem to be OK. Good luck
10-20-2019, 02:10 AM   #21
New update to my post #18:
I reported the problem battery to the Amazon Marketplace supplier ("QiaoJL") and it has agreed to replace the faulty unit because it is within its 24 month warrantee period - that should be arriving on Tuesday 22nd.
BTW: the other clone from the same source at the same time seems to be OK as it took the normal "long time" to charge up, whereas the faulty one showed "fully charged" in less than 30 mins.
OTOH: 2 more bought from the same supplier in October 2017 are definitely faulty - so it seems that that these D-Li109 clones have a usable life of 2 years but little, if anything, more than that.
10-20-2019, 04:14 AM   #22
QuoteOriginally posted by Cerebum Quote
Thanks. I'll check them out. I hope it will be cheaper. The freight cost might kill me as I'm in the Philippines.
10-20-2019, 06:06 AM   #23
Would you say it is comparable to d-li109?
10-20-2019, 08:02 AM   #24
I think Watson ones are available in Australia. You may even get wasabis
---------- Post added 10-20-19 at 08:05 AM ----------
QuoteOriginally posted by fsge Quote
Genuine Pentax? Noooooo you get about half the life, but that is why they are cheap I use the genuine Pentax charger. I checked out their other products and the reviews are pretty good but we won't really know until I have used them for a while as performance sometimes drops on the cheap stuff
10-20-2019, 08:48 AM   #25
Robin's Avatar
I have a Hahnel LI90, which will give you about half the life of a Pentax, and another mysterious Chinese made one, which is good for about a third of the time. Probably best just to stick to Pentax originals.
10-20-2019, 09:25 AM   #26
csa
csa's Avatar
Have a look at Wasabi or, if they're available in the US, Watson. They've been impossible to differentiate from my OEM batteries and have worked for many years.
I agree. I've had a Watson, since I've had my K3. I cannot tell any difference in the Watson and the Pentax battery. Both hold the charge well, and last about the same.
10-20-2019, 09:28 AM   #27
Last time I checked those batteries were at 1600mAh so a much higher level than pentax one. I guess these is wrong info then
10-20-2019, 02:04 PM   #28
Absolutely. I think the Pentax is 1050mAH. Another brand that I have used with my K3 is patona. Once again, not as good as the original but they have been reliable
10-21-2019, 06:33 AM   #29
What other good sites do I go to besides eBay and Amazon for these batteries?
10-27-2019, 04:41 PM   #30
johnha's Avatar
I have 4 genuine D-Li90s and cycle them round my cameras. The beauty of Pentax is that these batteries fit my K-5, K-1 & 645D and are generally inexpensive. While I might be tempted to use a 3rd party battery in my K-5, there's no way I'd do so in the others.
3rd, 3rd party batteries, batteries, battery, camera, charger, dslr, hahnel, party, pentax, photography
3rd Party batteries? jbmiller Pentax K-1 & K-1 II 10 04-17-2019 03:10 PM
Recs wanted, 3rd party D-LI109 batteries & travel charger, memory card Riverlady Pentax KP 17 12-11-2018 06:19 PM
Capacity measurements of some 3rd party batteries docswanson Pentax Camera and Field Accessories 14 08-01-2017 01:32 PM
3rd party AC/Car charger for D-Li90 batteries, $6! mikeSF Pentax Price Watch 6 04-17-2015 12:41 PM
All times are GMT -7. The time now is 03:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
