Another vote for the
AF280T. When used with a K or M lens on your AP, it will provide both auto-thyrister and full manual as well as basic flash dedication in M mode as if it were mounted to an ME Super film camera, meaning:
- Option of automatic flash exposure (two ranges)
- Changes shutter to maximum sync speed unless the current set speed is lower (may be overridden)
- Shows flash ready in viewfinder
With A-series and newer lenses, it will do the above tasks as well as set the appropriate aperture to match the camera ISO and flash range setting, the exact behavior depending on camera exposure mode.
Although flash zoom is not supported, the pattern is adequate down to about 18mm on APS-C without need for the optional (and hard to find) wide-angle diffuser. There are only two manual settings, H and L, with guide numbers of 28(m) and 8(m) respectively. Amazingly enough, flash modifiers are available that fit this flash. I have Sto-Fen Omni Bounce that fit the AF280T and several others. (The AF280T was made for about 20 years, up until at least 1998.)
I have found that my AF280T is often a less troublesome alternative, even with modern lenses, than my P-TTL flash.
