Originally posted by ChristianRock But if you use the "Apply All" setting in the AF Fine Tuning, it applies even to manual focus lenses! I used it first with my K20D which required AF adjustment of -1 for all lenses. I've also tried it with my K-S1. It works!
Thanks, I'll try it. Though that raises a different question: does the use of "apply all" do anything to the stored values I've entered for autofocus lenses? (Obviously, the documentation provided by Ricoh doesn't go into that much detail.)
Originally posted by othar In that case you could exchange the plane focus screen with a spilt screen. I havn't done it myself but I think I have read it is possible.
I have tried it. In the K-1, it was a disaster. The screen I got from "FocusingScreen.com" was a cut-down Canon screen that is smaller in width and length but thicker than the original. Just plain wrong size. Attempting to use the split-screen focusing aid was what got me to worrying about this (with concomitant testing and analysis) in the first place.
Originally posted by othar For a full manual approach and fast lenses wide open it doesn't help much, but focus confirmation (which is influenced by lens calibration) is still possible with manual lenses, too
That apparently doesn't work with back-button autofocus, which I use because I like to manually control everything - which is how I got into this - I generally use manual focus in preference to autofocus. Apparently, it works if shutter-button autofocus is turned on. I generally ignore that display in the viewfinder, anyway - can't see it all that well, anyway (wearing glasses increases eye relief distance reducing perceptible size of the viewfinder display). Another observation about the supplied documentation: the phrase, "focus confirmation" does not occur in the instruction manual that came with the camera.
