03-03-2007, 07:34 AM   #1
K100D won't accept new Sigma lens?!
Help! My new Pentax K100D doesn't appear to accept a new Sigma 18-200mm (F3.5-5.6) lens that is designed specifically for digital cameras. The lens attaches to the camera without a problem but I get a flashing "Av" aperture priority signal. The same thing happens with my Pentax ist DL camera. The screen on top of the camera flashes "Av" constantly. Nothing I do seems to remove this Av indicator. Does anyone know why this happens?
03-03-2007, 07:44 AM   #2
-=JoN=-'s Avatar
could be a faulty lens. I had issues when I purchased a sigma before, it didnt give the body the correct aperture reading, and was not AF-ing
you might have to return it or send it to sigma
anything else it's not doing?
if it's doing it on 2 bodies, the more than likely it's the lens. i tried mine on film and the k10, both problems. give them a call, their service reps are pretty nice..
03-03-2007, 09:14 AM   #3
FotoPete's Avatar
"DC" means the lens forms an image circle to fit APS sensors only. (Plus some coatings to prevent reflection on the back element.)
Sigma does not have access to proper mount design. Companies don't like to give their mount workings away or else others will make lenses and sales of the original brand lenses would drop hurting the company. Canon is most notorious for this.
Third party manufacturers have to usually buy the brand name lens and dissect/reverse engineer to get at how the mount + electronics work. Usually its a hit and miss and everytime something new alters slightly for that mount, those Sigma lenses need to be sent back to Sigma to be "rechipped".
Maybe thats the case with your lens. Take it back to the place you bought it and explain the problem.
Wait, does your Sigma lens have an aperture ring? If it does, then keep the ring on "A" position and change the aperture on the camera via the back dial. cuz that might be the problem.
03-03-2007, 09:40 AM   #4
*isteve's Avatar
Is aperture ring set to "A"?
QuoteOriginally posted by jdpenk100d Quote
Assuming it has one of course.
03-03-2007, 10:08 AM   #5
isteve beat me to it
First thing I thought was "I'll bet the lens aperture ring isn't set to "A". It's happened to me a couple of times, I'll put the lens on the camera and get the Av flashing, look at the lens and sure enough the lens is off of the "A" setting.
NaCl(check the simple stuff first)H2O
03-03-2007, 06:47 PM   #6
is it a grey market lens?
Thanks for your replies everyone. I bought this lens from Broadway Photo and I'm now suspicious it's a grey market Sigma lens that's incompatible with the new Pentax digital SLR's even though it's advertized as a "digital camera lens". Makes me mad because Broadway didn't advertise it as grey market and I thought the problem was with my old SLR. Now I have an expensive new lens I can't return and I can't use.
03-03-2007, 06:55 PM   #7
-=JoN=-'s Avatar
are you 100% sure it's grey?
and regardless of market, it should work, i have lenses back from 1998 from sigma that works fine with the k10. it's a faulty lens, period, even if you put that on an older film body i doubt it will work.
and why cannot you return it to broadway photo?
the digital designation is just an small tweak, it's optimized for digital use, but not specifically made, unlike the DA's
03-03-2007, 08:13 PM   #8
"Thanks for your replies everyone. I bought this lens from Broadway Photo and I'm now suspicious it's a grey market Sigma lens that's incompatible with the new Pentax digital SLR's even though it's advertized as a "digital camera lens"
i think u are way off with that one.. i have older sigma film lenses that work perfectly with my k100..
trog
03-04-2007, 01:24 AM   #9
If it is a DC Lens it has no aperture ring
What is happening is the electrical contacts are not connecting properly, what you need to do is clean both the lens and body mount.
camera, dslr, k100d, lens, pentax, photography, sigma
Pentax K100D Super with Sigma 28-200mm lens - Not working? JSM Graphics Troubleshooting and Beginner Help 3 04-08-2011 09:35 AM
Hello FRIENDS..!! Please accept me in this Pentax FAMILY. Ta. alexthomascv Welcomes and Introductions 3 04-04-2011 10:15 PM
can K-X accept M mount 50mm F1.2? surfmanjoe Pentax DSLR Discussion 8 07-21-2010 03:04 PM
K10D won't accept Pentax-M 135mm prime lens jdpenk100d Troubleshooting and Beginner Help 11 02-19-2009 05:42 PM
lens for pentax K100D Sigma 50mm 2.8 ex macro fevbusch Pentax DSLR Discussion 7 02-04-2007 11:32 AM
All times are GMT -7. The time now is 01:08 PM. | See also: NikonForums.com, part of our network of photo forums!
