Originally posted by tduell The questions re refocussing are interesting.I'd need to see some good data that the refocussing really made any noticeable difference under the test conditions
If that's of interest to you, I can describe my Af fine tuning experiement.
I've done an experiment with my K1 and D-FA 28-105 @ 105, 60 AF shoots alternating each shot with pre-focused manually (turning the focus ring) at nearest focus distance and prefocus at infinity, that's 30 shoots prefocused at nearest distance and 30 shoots prefocused at infinity. I've alternated near prefocus and infinity prefocus to eleminate the effect of gradually increasing temperature inside the camera for the duration of the experiment. Then I plotted the MTF of test chart, and I could see two populations, one population of the shoots pre-focused at infinity separate from the population of shoots prefocused at nearest distance.
Then, I've repeated the same procedure but without touching the focus ring for the pre-focus operation, using the camera AF itself and a movable target to force the camera to focus near or at infinity (the camera will stop focusing at infinity is the targe is too close, I set the movable target closer to nearest distance to have the camera AF fail and default to focus the lens at infinity). Again captured 60 shoots alternated between nearest pre-focus and infinity pre-focus (30 shoots pre-focused near, 30 shoots prefocused at infinty, all using IR remote, 3 s. delay, and pixel shift for max sharpness from the sensor). Plotted the MTF distribution again. Still observed two separe populations, each centered around the mean value of near-prefocused samples and the mean value of the infinity pre-focused samples.
Interestingly, the gap between the two populations of near-prefocus and infinity pre-focus was smaller when using camera AF to pre-focus. I've use camera AF to pre-focus to compute the best AF fine tune value. In order to find the best AF fine tune value, I've shot again 10 shoots alternatively prefocused at nearest distance and infinity, for each of AF fine tune setting from -10 to +10 (that 200 shots, 100 shots prefocused at nearest distance and 100 shots pre-focused at infinity by camera AF itself). Plotted the mean value of MTF as a function of AF fine tune value, it looked like bell curve flattened around AF fine tune value = 0. Then I plotted the MTF value dispersion vs AF fine tune value, and I found the the dispersion was greater at the outer regions of the AF tune values. So , for example, the best possible sharpness was obtained with AF fine tine value = -8 but at that setting some of the shoots were softer than the worse shoots at AF fine tune = 0.
My conclusion was that AF fine tune = -8 would give the best possible sharpess, at the expense of having less than 50% of the shoots less sharp than when using Pentax factory default. I prefered to have a higher percentage of my shoot in good enough focus as opposed to having some of the shoots a little sharpner and some of the shots worse than default. So I decided to reset the AF fine tune to value 0.
