Originally posted by SSGGeezer K-5IIs, same basic layout, under 300 bucks, solid body, no AA filter with much better resolution. backlit LCD on top of the body, great ergonomics. If you are thinking new or lightly used, the next question would be, do you need a grip for extended battery life? If yes, skip the K-70 and look K-5 series, K-3, and KP. I love my KP but still like shooting my K-5IIs a lot also.
let us know what you end up choosing.
Ditto for me! Even though the KP is now my most often-used body, I still like my K-5 IIs very, very much!
Don't worry at all about the K-5 being too advanced and complicated over your K-7. You will find yourself right at home. The K-5 is very user-friendly with a great controls layout. But if you do go for the K-5, be sure to get the K-5 IIs, which, since image quality is of utmost concern, will provide more detail in images due to not having an AA filter. I know because I have a K-5 and K-5 IIs. Its AF performance was also improved over the original K-5. None of the subsequent Pentax models have an AA filter, but they now have a filter switch-in available in case of a problem with "moire". Its low light, lower noise performance is a major step up from your K-7 also, along with dynamic range, and even slightly better than the K-3. It is one of the great cameras, IMO.
But the KP takes things up significantly farther. There are more features than the K-5 or K-3 series. Low light, low noise advancement is outstanding, and a major reason that I went for it. IQ and metering- outstanding. There would be more for you to learn because its controls are different and it has no top LCD screen, but then you have the sometimes very useful pull-out rear screen, and the information on it is larger and more clear. I do still value the handiness of having a top LCD on my K-5 cameras, but coming from the old film days where there were no top LCD screens, making the re-adjustment with the K-S2 and KP for me was easy. I think with its fine imaging and unique design the KP might become a classic. And you can get it in a beautiful silver /black finish.
If you often shoot JPEG images, for best results right out of the camera with either model, be sure to set up "Fine Sharpening" in the Custom Image menus, especially in the most-often used "Bright" category. Both the K-5 IIs and the KP have very good in-camera processing for out-of-camera JPEGs, but the KP is really outstanding.
