Originally posted by SSGGeezer And this was a new Pentax branded battery? I am surprised that your numbers were so low when I could get over 400 min cool weather out of off brand batteries with my KP. What are your settings as far as noise removal and brightening?
Indeed, this was with the new battery as supplied with the KP. Initially I was prepared to consider it may need "forming" by recharging it a few times to bring it up to maximum capacity, but no. I've even used the original battery from the K-70 in the KP, but the KP simply doesn't seem to last as long. It's a difficult comparison to make directly as conditions vary from day to day, and I'll admit I've not sat down and simply clicked the shutter on either camera 'till the battery run flat. I'm just aware that having spent a couple of hours in the bird hide(s) and maybe walked about for an hour or two, a typical routine for me, the K-70 would almost always have had "something left" when I went home, whereas the KP will often need a second battery. Total frame count, in my instance, is probably slightly misleading, as there can be a lot of focussing and framing going on in a wildlife scenario, without necessarily always making an exposure, but as I'm still using the same lenses the overall power consumption should be similar.
Power save settings are similar on both bodies, as are noise removal and brightening ... indeed, having spent some time initially with my K-70 getting everything set as I wanted it, I diligently sat down with both cameras and went through the menu settings (where comparable) and set them the same! I do notice the KP takes a lot longer to "wake up" from initial shutter-button press to being ready for action, the K-70 is virtually instantaneous, so there's obviously "a lot more going on" to ready the KP for action.
