Originally posted by Larrymc
Wonder if Firmware 1.40 is the culprit??
It is hard to say. I am still on v1.30 with no particular reason to change up.
The RF or hard wired remote when in Bulb mode 1 do not act the way the body shutter button does when in Bulb Mode 1 which should be push-A/F-Open shutter-Hold- then when released - release shutter.
OK...I just ran a quick test with my wired remote vs. shutter button.
- Bulb mode (set to Bulb Mode 1)
- A/F mode 1 (AF on shutter press)
- AF-S Release priority
(Note: The above, except for AF-S, are the defaults)
Behavior using the shutter button is as you anticipated with the shutter opening on press and closing on release. Switching to my wired release (
LINK to Review) in immediate mode, I get the same behavior as with the shutter button.
Theories?
-- Something changed in firmware v1.40?
-- Your wired/RF remote is setup to emulate other than Pentax?
-- You are set up to require focus before opening the shutter, but focus is slow to acquire, but snaps on second attempt? (yes...I am desperate...)
Sorry
works for me...
