Originally posted by DrawsACircle I would claim it’s well below 1%. I have a 3yo. 15.000+ shuttercount K-70 and would not hesitate to buy it again, I will also, at any time, recommend it to other users.
Failure rates and weibüll analysis is a part of my everyday work, knowing/accepting all components have a failure rate, I consider the risk of my K-70 failing as being neglectable compared to what else could go wrong when using it.
Why well below 1%? number of sold units (not known but, hopefully, xx thousands) number of known failures?
No issue if you ask me, if it fails we even have a fix.
There is a noticeable failure rate, below that of the K-30 but noticeable.
Your K-70 may be fine, (*) but we get a steady trickle of visitors here {most of whom are unaware of the issue before they ask} asking about dark images, a trickle which does not occur for any other camera series.
Yes "we have a 'fix' " - we also have a 'fix' for heart circulation issues, but I hope you would not recommend an exercise-free lifetyle because we can 'fix' {via heart-bypass} problems that can occur.
BTW - unlike other camera problems, Dark Image Syndrome seems most likely to happen to cameras that are not heavily used, so your 5000 annual shutter-count is actually an argument in favor of your being one of those who do not have the problem.
(*) If the failure rate is 10%, we would expect the majority of K-70 cameras to not have that problem - that is what 10% means.
