Who knows how many K-30/50 bodies were affected. In my case it would be 100% since both my K-50s failed. I fixed them myself by replacing the "green" solenoids with "white" ones & they've been trouble free since. Mind you that they both failed with very high actuations (+-25,000). They were used a lot & it didn't even matter. It seems that low actuation K-30/50 bodies have a high failure rate from not being used.
In the case of the K-70, we're probably going to see less failures, since Ricoh had the "green" solenoid slightly modified. But even though Ricoh made a slight change to the solenoid, it still doesn't resolve the faulty part 100%. It's going to be a matter of luck with that camera, but my guess is that there will be less failures in the long run.
Would I buy a K-70? Nope. I'd just skip right on to the KP if I were desperate for a Pentax APS-C camera at this moment. I'm not, so I'll be waiting for that upcoming APS-C flagship.
