Originally posted by MarkJerling Of course, it depends how close you plan to stand to that large poster.
According to my calculations, based on angle of binocular vision of 120 degrees (and confirmed by experimentation), the closed viewing distance is 1/2 of the horizontal print size. e.g viewing a 60" print at 30" from the print.
---------- Post added 17-12-19 at 08:31 ----------
Originally posted by Dan Rentea Biz-engneer, you heard that? Maybe you will take another look at your options.
Yes, it's an interesting article.
Originally posted by BigMackCam Personally, I recommend deep breaths, and a moment or two away from the computer before clicking the "Submit Reply" button
The preview (and read back) button helps a lot. But that button is only available in advanced mode.
---------- Post added 17-12-19 at 08:34 ----------
Originally posted by photoptimist If you downsample a 16-bit 150 MPix Phase One image to something like an 8 MPix file for A4 printing at 300 ppi in a magazine, it seems like a waste of pixels but it's not. It creates an image file with probably about 17-18 EV of DR. The result smokes the pants off APS-C for highlight protection, shadow recovery, high-fidelity color, and high-iSO work.
That would be true in theory, however the paper printing process is the bottelneck that can't print such tone gradation and dynamic range information from MF to A4 paper. Practically, the addition image quality from MF is wasted during the printing process on A4.
---------- Post added 17-12-19 at 08:37 ----------
Originally posted by Fluegel Start trusting your eyes as the best way to enjoy photographs.
Of course MF prints look better but it's not possible to realize it unless taking two photos from FF and MF and comparing the prints side by side. It's simple, at constant PPI, the larger format with larger MP count allow larger prints. The real problem of MF is the price of equipment, not everybody can afford it, hence there is no need to demonstrate that FF is as good as. With regards to image quality MF is better and more expensive.
---------- Post added 17-12-19 at 08:41 ----------
Originally posted by Wasp FF seems to occupy the sweet spot for hand held low light work.
Low light wasn't a parameter in the equation in my orginal post. The starting point was the final image product leading to the choice of equipment. Someone introduced low light to bring about the advantage of the full frame format.
---------- Post added 17-12-19 at 08:44 ----------
Originally posted by Serkevan I got nothing but snobbism
Snobbism could be interpretted as such . But there was genuine content in the message (under the form of expressing the message).
---------- Post added 17-12-19 at 08:49 ----------
So , full frame is good for low light works, the apsc format is good for high speed shooting, and medium format is good for landscape and architecture on a tripod. If we introduce factor in the enlargement in the equation, the fact that full frame is good for low light doesn't remove the other facts that medium format is an overkill for calendars and apsc is a bit of a stretch for large posters. If weddings is not your cup of tea, you don't use full frame, you use apsc or apsc and medium format.
