Hi all,
I thought I'd pose a question to the forum, since I'm unable to understand why it happens. I hope someone has the knowledge to answer me. First, some background.
I have a Pentax K100D, going on on year now. The camera seemed to function well with both the 18-55 DA and 50-200 DA kit lenses. Yet, after some time of use I noticed that some shot aren't as sharp at certain focal lengths as others. With experience I became more familiar with how to judge image quality in a photo. This led to me inquiring with my father about an old Pentax film SLR that I remember from my childhood. He went through the closet, pulled out an old Pentax ME body with the lens still attached.
This turned out to be the Pentax-M SMC 50 f/1.7 lens. I suddenly began to learn photography 'old school' and began using the lens almost exclusively for some months. I became quite frustated with the focus consistency, as the focus screen did not have the ability to distinguish sharp focus at such wide aperture, so I purchased a split screen from eBay and installed it myself. Success! Now all my photos come out in sharp focus with the manual fifty.
I began to notice however that 'perfect' focus in the split screen did not light up the AF green haxagonal focus indicator in the viewfinder. After some testing, I discovered that indeed the split screen was correct, and assumed the AF sensor plane was not quite the right distance from the mount. After much research I found that the K100D has a service mode which you can enter and input an AF bias, which basically corrects AF in software. After some tinkering with values and a focus chart, a value of +30 micro meters was used, which led to both the AF indicator and split screen calibrated perfectly together... or one would think. The manual lens was working perfectly, the kit lenses became sharper, everything was great. (*NOTE* I do not believe the +30 value actually shifts the sensor plane at all, but I do believe it creates an offset in software to correct for the AF - so in essence it would be as if the plane was moved)
This is where I became lost.
Growing confident in my ability to handle and calibrate equipment, I purchased a Tamron SP 28-75 f/2.8, to be able to auto-focus in low light and have a very versatile 28-75 zoom while sacrificing very little in resolution. The lens just arrived and I am totally confused as to what I am seeing.
First, the lens front-focused terribly in AF. I thought to myself, no big deal, I'll just MF the lens. That ALSO did not work, even though the split screen showed the scene was perfectly in focus, upon reviewing the photo, it is obviously front focused. So both the AF sensor (which is calibrated using the 50 to the split screen) and the split screen are not able to focus this lens. In a last ditch effort I was able to get the lens to autofocus properly using the service mode... using a value of -250 micro meters as the AF bias.
So now, the lens will autofocus properly. However, the viewfinder shows a very large discrepancy in the scene, which is now visibly 'split' in the split screen. How can this possible by? Since the camera was calibrated with the original +30 micro meters I've ensured that the optical length between the mount and the AF sensor plane is the same as the distance between the mount and the split screen - which produces SHARP photos when focused with any of my other lenses.
I could understand if the AF was misfiring and not actually focusing the lens, which could then be correctly using the split screen image... but a perfectly focesed viewfinder image will still produce backfocus. How is this lens able to project light correctly in one optical path but not the other? I sincerely hope someone has an answer and explanation to this, as it is beyond what I can figure at the moment.
Geoff
