Originally posted by MotoMind
The K10D is an objectively obsolete camera. It does not do anything that cannot be done by more modern cameras with postprocessing to get the feel you want if necessary. The color information is there to work with.
From Merrian-Webster:
ob·so·lete | \ ˌäb-sə-ˈlēt , ˈäb-sə-ˌlēt \
Definition of obsolete (Entry 1 of 2)
1a: no longer in use or no longer useful
an obsolete word
b: of a kind or style no longer current : OLD-FASHIONED
an obsolete technology
farming methods that are now obsolete
I personally don't like when people use the word obsolete because they mean something that needs to be replaced - or that it can't be used anymore. When in fact it's just no longer current. The K10D is as obsolete as the K-5. It's not the current model.
Film is even more obsolete in that sense, but it still has its uses. It still brings in the money for Andreas Gursky... so how can it actually be "obsolete"?
Manual transmission cars have been "obsolete" for decades but still have about half the world market.
Cars were invented by bicycle manufacturers in the late 1800s and were supposed to replace them and make them obsolete. But let's look at this statistic from
Worldometer - real time world statistics "As recently as 1965, world production of cars and bikes was essentially the same, with each at nearly 20 million, but as of 2003 bike production had climbed to over 100 million per year compared with 42 million cars."
I would argue that something is not obsolete as long as it is preferred by someone. If you come by the K10D Club thread, you will see it is still preferred by a few people out there. Including me. Is it the best "jack of all trades"? No, but is that the definition of a non-obsolete product? I don't think so.
Quote: What the K10D does provide that more modern cameras sometimes do not provide is exceptional ergonomics in terms of size and shape, durability and water resistance, shoulder display, minimal LCD use, efficient always-on/sleep, and very fast power-on to shoot times for maximum battery conservation.
This amounts to functionality appropriate for a top of the line professional camera for its time, and the physical shooting experience even today reflects that superiority over low and and mid range cameras and even many prosumer cameras that cost 10x more.
No arguing there...
Quote: Aside from that, one must accept and embrace its limitations. Yes, it looks best at low ISO, but you will fight dynamic range issues. You will adjust EV to preserve highlight detail, and your photos will be dark. You will need to use prime lenses with a fast aperture, like the 50mm DA. You will sometimes use a high ISO and accept the noise. You will have blurred photos. You will shoot RAW to avoid turning sensor noise into JPG grease. You may use flash indoors. These are things forced on you when you want to simply take a shot in bad conditions.
Again, no it's not a jack of all trades, but no Pentax is. If you want a camera that has the highest resolution, the fastest autofocus, shoots the most frames per second, has the most compatible lenses that are sharpest edge-to-edge wide open, and the absolutely best sensor in existence, you will be shooting with other brands - and even then you might struggle to be best in class in every single aspect.
And most people don't need best in class in all these things at once, if at all.
The question should always be, what is the requirement for the photographer, and does this camera do it well?
Quote: It is also fine. Limitations display what we sometimes see as character, and which, if embraced and worked artfully, can demonstrate a style. Perhaps as ungraceful and anachronistic as using straight skis in the age of side-cut, but if that is what you enjoy, that is what you should do.
In other words: be a luddite if you want to
By the way, anyone wanting to get rid of all those obsolete Limited lenses that still use screw drive autofocus (I mean, really, who still sells that????), send them to me and I'll properly dispose of them
