Originally posted by JensE With respect to manual focusing, I had questions that I wanted to clarify: (How) Does the light intensity impact D+ - D0, or the range until the focus indicator turns off? Similarly, what about the light color? What about subject contrast?
Hi Jens,
Thanks for posting your interesting findings.
I have not conducted any tests to specifically address light intensity, light colour, or subject/target contrast in the context of manual focus calibration or the behaviour of the focus indicator.
However, throughout my focus calibration work, I have observed that the
colour temperature of the light source does not affect the AFFA settings on my K-5 II or K-3 II. I have used CFL, LED, halogen, tungsten, and natural light, with colour temperatures ranging from 2700 K to 6500 K. For example, for some of my lenses, I had calibrated with two or three different light sources, arriving at the same AFFA settings. On the other hand, if I recall correctly, the autofocus of the K-5 with its early firmware
was affected by tungsten incandescent lighting.
I haven't noticed that light intensity has any effect on the
range of the focus indicator. My artificial lighting is normally adjusted to provide for my desired shutter speed and aperture.
I would think that the
contrast of the subject target is an important factor. While targets of opportunity may provide good results, I have tended to use a high-contrast target like the one I illustrate in the article. It helps to eliminate a variable in the process.
Originally posted by JensE I first used the FA31mm on my KP at 1m distance (sensor - target), and the live-view magnified focus put the distance scale right on the 1m mark. However, for this combo, D+ and D- are so close that they are less than the thickness of the '1' stem on the focal scale. My AF calibration using 'slanted ruler next to focus target' method was spot on for this lens. I did however observe that the focus indicator only turns off at nearly exactly the f/4 DoF scale marker in either direction.
I don't own a copy of the FA 31mm to compare directly with your finding. However, I ran a controlled test on my K-3 II with my calibrated
SMC Pentax 30mm f/2.8, which has a similar focus scale. Using magnified Live View, the sharpest focus was at the vertical stem of the '1' meter mark, and the in-focus range was very tight. Using viewfinder PDAF and focusing from the infinity side, the indicator illuminated when the '1' was aligned with the orange diamond marker, and turned off when it aligned with the left-hand f/4 DoF mark. So, I would say the behaviour is similar to your FA 31.
Thanks again for your observations!
- Craig
