Originally posted by Leumas
Not sure if anyone has mentioned this, so I thought I would.
When doing composite shots a long while back I couldn't figure out why they were coming out so blurry. Turns out the culprit was horizon correction.
So quick tip for composites
Interesting... I don't quite understand why that should be the case.
I assume you're talking about the K-1's auto horizon correction where the sensor's SR mechanics are used to rotate the sensor? If so, are you continuing to shoot with SR enabled (such that it might interfere or reach rotational limits in combo with the horizon correction)?
Do you have an example you could share of the source images? Also, what software are you using for the composites?
I'll be honest, it doesn't sound like horizon correction is causing this in isolation, but that there may be a combination of factors. At least, that's my starting point...
