Originally posted by johnha The TTL metering should account for the extension as it's through the lens. If using a handheld meter or manual flash, you'd have to make a correction. It depends on the camera to subject distance amongst other factors.
You'll need to use stop down metering (lens auto/man switch on man).
Exactly.
If you are using an external light meter or lighting calculations (e.g., sunny f/16 or aperture calculations based on a manual flash), the correction formula isn't too bad
Just multiply the "no-tubes" aperture by F/(L+F) where L is the length of the tubes and F in the focal length of the lens. Thus, if you are supposed to use f/16 and have 45mm of tube on a 90mm lens, the lens aperture needs to be 16 * 90 / (90+45) = 10.7 which is close enough to f/11 for government work.
