Originally posted by rqy99g I can see the benefit of an articulating screen, in particular for awkward and low locations.
For low locations the tilt-out screen is better because it doesn't take up room to the side of the camera. It is also handy for on-tripod work with the tripod set at a low position, or at waist height, where It saves having to bend over. In addition to checking settings, etc. you can shoot in live view instead of using the VF if you wish.
The swing-out screen as on the K-70 can be reversed, protecting the screen when not in use. It can also be useful for doing a selfie with a friend using a WA lens. Like the K-S2, the K-70 actually is designed with a dual-purpose button for such selfie use positioned for being a second shutter release button when the camera is held backwards. Pretty neat designing.
Both types of screens have advantages of their own.
---------- Post added 03-05-20 at 12:05 PM ----------
Originally posted by MrB1 If you have done a comparative study of the K-70 and KP (links avalable previously somewhere in this thread) you will not have failed to notice the superior photographic technology and feature set of the KP. The K-70 is certainly much more than a "perfectly adequate" camera, but the KP is on even higher levels than that. To list a few: the AF module, the metering module, the mirror/shutter/aperture mechanisms, the electronic shutter, the three control e-dials. If your next purchase will be your only recent camera, and you expect to be using it for many years, then I would consider the best advice is to be patient, waiting for the next round of special offer price reductions, then get a new KP with 2-year Pentax warranty from a Pentax dealer (e.g.SRS), hopefully for between £500 and £600. If any new K-70-level model is released, it is likely to cost at least as much as the discounted little gem that is the KP.
Philip
Absolutely. Much better set of controls and other useful features, in addition to a better more durable build quality and the availability of a battery grip. With the battery grip, the combined weight is about the same as the K-3 II without one, and will provide more battery life than the K-3. It also provides a lot of gripping surface for better carrying balance with larger lenses, as well as convenient duplicate controls for doing vertical shooting.
