Originally posted by stevebrot An explanation of DNG color matrices requires a deep dive into the DNG specification and I ain't gonna go there!!
Color matrices have nothing to do with WB
The multipliers I am speaking of can be found in non DNG files also, this is what WB is its multiplying 1 or more of the color channels to produce a white balance. The multiplying of the color channels is done independently of the profile used. and does not change when changing the Color matrices ether in a profile editor or the color matrices tab of ARC.
We can see this if we simply change the multiplier stored within the raw data regardless if it is a DNG. It only makes adjustments to the WB setting and only the WB sliders. We also know this because to use the multiplier data within the raw converter you can only use this data if your select "as shot".
Here I have used the multipliers that are measured by the camera WB settings
Here I have set them with no multipliers meaning no WB is being applied to the raw file. If you look you can see that the WB sliders have changed and this is the UniWB setting for this camera model red=1 green=1 blue=1
Every forum that I have participated in call these multipliers
Do Not Let White Balance Throw You Off-Balance | FastRawViewer What is UniWB? | DSLRBodies | Thom Hogan
