Originally posted by CarlGundel Mount a Pentax K or KA lense.
Set the aperture using the lens aperture ring.
Set the shutter speed using the e-dial
Press the shutter button to take a photo
...and the shutter speed remains where I left it. This does not happen with any of the settings I have tried.
I just want the camera to do what I tell it and not try to be 'helpful'. Very annoying.
Are you in X-mode? If so, the shutter speed should be fixed at 1/180s.
Are you in B-mode? If so, the shutter will remain open until released.
Are you in M-mode? If so, the shutter speed should remain where you set it, unless you push the green button, in which case, it may change because pushing the green button tells the camera to stop down the lens and meter.
Are you in P, Sv, Tv, Av, TAv? The aperture will remain wide open regardless of setting and the shutter speed will vary according to light.
Are you in Green mode? Same as immediately above except always auto-ISO.
If not behaving as above, your camera is broken.
