10-29-2008, 07:49 PM   #1
kev.pride's Avatar
K10D questions
Have just got my hands on a well looked after K10D, but I have a couple of questions for the more enlightened on the forum.
(1) Mirror has fine dust & small hairs which are probably what I can see through viewfinder - are these easy to clean off.
(2) I mistakenly inserted an SD card when it still had 2 photos from my K100d and now the camera is using these numbers + on subsequent photos I've taken with the K10D - am I stuck or can I reset the numbers.
regards
10-29-2008, 08:05 PM   #2
JonPB's Avatar
Mirror dust can probably cleaned just like sensor dust--use a blower. Although, for my camera, I'd be content with dust on the mirror because knocking it off the mirror might land it on the sensor. Viewfinder dust is easy, too; there's a good video on YouTube about replacing viewfinder screens, just follow that procedure to remove and return the screen.
For image number, I'd try Capture Menu, Memory of Settings, File No. But that's just a guess.
10-30-2008, 04:17 AM   #3
brownargus's Avatar
QuoteOriginally posted by kev.pride Quote
regards
To reset the image number, refer to p199-200 of the manual. Basically, press Menu. In the record mode advance to Memory and press right arrow to bring up a new menu; scroll to p2, where the last entry is File No. If this is ticked, then numbers will continue from the previous numbers recorded, i.e. the camera remembers the image numbers even if another card is used. Unticking it makes the camera revert to no. 1 for the next image when a new card is inserted. I don't think this will work with a card that already has a number of images on it because you would then have two images numbered 1, etc. The only way is to try it.
Even though the two cameras are from the same make, it is safest to format a card in the camera it is to be used in to avoid card reading/recording problems and corrupted images.
Hope this helps.
John
camera, dslr, k10d, photography, photos, questions
k10d questions cutlerjay Pentax DSLR Discussion 7 11-03-2010 03:13 PM
Questions about K10D sweet bay Pentax DSLR Discussion 7 01-17-2008 11:54 AM
Two questions on the K10D Jimfear Pentax DSLR Discussion 11 11-27-2007 12:18 PM
K10d Related Questions Takman Pentax DSLR Discussion 5 10-31-2007 12:03 PM
Other K10D questions then. steffi Pentax DSLR Discussion 16 04-17-2007 05:18 PM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
