Originally posted by Michaelina2 Does installing one of these things
void your Pentax warranty, or extended Pentax warranty?
There are two issues to consider here, just to be clear.
If you complain to pentax about metering, and send the camera in with this screen, they will do nothing, exxcept perhapos charge you because the camera is "modified" and they don't support modifications.
Also, if you have damaged the mechanism by changing screens, they will again charge you for this, even though the screnes are user changeable.
If, however, you retrun the camera with an "approved pentax screen" which is any one listed in the manual and the changing of screnes is NOT related to the issue with the camera, then the camera would be considered to be still under warranty (assuming it has not expired)
