Originally posted by emalvick With regard to the manual aperture and lens, I still essentially do the EV comp... it's the shutter speed. I typically shoot manual and select an aperture and then a shutter speed to get the exposure as I want. If I chimp the histogram and I need an adjustment, I usually just shift the shutter speed to get the EV I want.
I don't disagree, but it is not as easy or simple as it
A should be, or
B is on my *istD which meters corretly with pushing the green button on any manual apature lens.
For most cases, it is not an issue, either with lenses stopped down below F8 because you always have to add about 1 1/2 stops,
BUT the issue is with a fast lens, where depending on apature at the time, the compensation can be over, under or none, it is a bit of a pain. As I said earlier, my real problem is that when shooting with a long lens, through shadows and constantly changing apature, it becomes rather bothersome. If I am just out walking about, I will meter off the road (18% grey) set things once and be done with it.
