05-11-2020, 05:13 AM   #16
With that lens stable I would consider waiting for the K-new as @mikesbike says; it should be a straight upgrade from the K-3ii in all respects. Since you have the 150-450 and 55-300 I suppose that wildlife is important to you? If that's the case the K-1 might not give you too much joy as it has a lower frame rate and you will also sacrifice reach.
05-11-2020, 09:41 AM   #17
zzeitg's Avatar
For still life photography or landscapes K-1 is the right camera, thanks to its IQ. For wildlife and action shooting K-3 gives more sense (higher fps, longer reach).
Most probably you need both :-).
05-11-2020, 11:15 AM   #18
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by zzeitg Quote
. . . you need both :-).
better safe than sorry right
05-11-2020, 03:34 PM   #19
Same bird and about the same distance away with the 150-450mm. One photo was taken with the K3 and the other with the K-1II, and then cropped to the same dimensions.
PENTAX K-3  Photo
PENTAX K-1 Mark II  Photo
05-11-2020, 04:09 PM - 1 Like   #20
dbs
QuoteOriginally posted by tmlawes Quote
Hi
For myself I prefer the second photo between the two.
I have not had a peek at the exif ,
Dave
05-11-2020, 05:17 PM   #21
Second photo is a bit sharper - K1ii. Very nice.
Thank you all for youe thoughts on the thread.
05-11-2020, 07:39 PM   #22
In the top photo, which I'm assuming from the above designation, is from the K-3 (?), the bird's positioning is not so favorable, and the DOF is very shallow, while focusing has only its feet and the branch it is on as relatively sharp, while all else is defocused to various degrees.
In the bottom photo, designated from the K-1 II, the bird is in much better position, and the DOF is much greater, with much more of the bird and its immediate surroundings being relatively sharp.
This difference in DOF is the reverse that one would expect between the two photos if their presumed identity is correct. If I had no presumption, no knowledge of the particulars of processing, etc. and I were guessing which is which camera by just looking, because of the DOF difference, my guess would be the top photo being from the K-1 II and the bottom photo from the K-3.
05-12-2020, 01:53 AM   #23
QuoteOriginally posted by mikesbike Quote
Nope, the EXIF says that the top photo is the K-3. The K-1 image, however, is taken at f/6.3 which affords a bit more DOF while, crucially, not being wide open.The DOF thing is a can of worms*, because it depends on how you're looking at it: for the same focal length and subject distance, the crop camera will have less DOF because the image is more magnified. If the framing were to be made the same framing by using a TC on the K-1, it would have been a different story because the FL would come into play.
*My head started hurting again while thinking about it
05-12-2020, 02:28 AM - 2 Likes   #24
noelpolar's Avatar
Clearly, the birds put in extra effort when posing for the K1. This has been noted through the years in photography.... every model focuses more when the big camera comes out. This supports my position of K1 for the 150-450......
05-12-2020, 03:06 AM   #25
zzeitg's Avatar
ISO 640 vs ISO 320, plus the fact that K-1II is handling noise better than the old K-3.
aps-c, camera, dslr, k3ii, kp, lenses, photography
For Sale - Sold: (Sold) K1ii + DFA28-105, DFA15-30, FA77 Limited and Rokinon 135/2.0 iGarfinkle Sold Items 14 12-26-2019 05:15 AM
K1ii RAW not read by Mac micmrc Pentax K-1 9 05-12-2019 03:48 PM
K3iii vs K1ii troika Pentax DSLR Discussion 36 09-10-2018 12:24 PM
Is K1ii better than K1 for capturing moving subjects? Billk Pentax K-1 12 06-01-2018 11:34 AM
All times are GMT -7. The time now is 03:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
