Show Printable Version 77 Likes Search this Thread
12-12-2021, 04:27 PM - 2 Likes   #61
cobbu2's Avatar
It wasn't until less than a year ago that I discovered my K-5 was Astrotracer capable (with the OGPS-1) until I updated the firmware. And it works! Before that, I thought the only way I could do it was with my K-3 II or KP.
12-15-2021, 03:05 AM   #62
After like half of the year of reading a manual and messing with settings of my K-S2 I discovered the mighty power of Green Button and Optical Preview of depth of field. I think the possibility to change the focusing screen is one of those things too.
To be honest, I still encounter new, fun features, like in some kind of journey.
12-15-2021, 03:34 AM   #63
Never tried back button auto focus until recently. I guess I knew it was a thing, but never bothered setting it up. Now have it set up on both of my main bodies...but I'm still forgetting about it sometimes!
12-16-2021, 07:14 AM   #64
Jonathan Mac's Avatar
In the last year I have started, occasionally, using the "Radiant" jpeg profile on my K-3. Previously dismissed as horrendously garish, I've found that it's good for the times that I see something which to the naked eye stands out due to it's colour, but when photographed often seems flat and dull and simply cranking up saturation and/or contrast in another profile just sends it over-the-top. I do usually have to tone it down a little in the fine-tuning, but it's good to finally be able to produce something that's much closer to what I saw with my own eyes.
01-28-2024, 11:20 AM - 2 Likes   #65
Kevin B123's Avatar
I don't know when this magic turned up, but I got the nod in a thread on here somewhere (lost it now), anyhow:
On the K-1ii with C26 enabled, you can be in Av, TV, P or Sv on a manual lens without contacts eg an M 50 f1.7 and just set the aperture on the lens and shoot. No green button metering is required.
Exposure compensation works as normal.
Perhaps this was in a firmware update or there all the time, but I have just seen it working. I've always used the green button to set the exposure before.
01-28-2024, 12:51 PM - 1 Like   #66
That's very cool.
01-28-2024, 01:20 PM - 1 Like   #67
QuoteOriginally posted by Kevin B123 Quote
They introduced functionality like that on the K-3iii at some point in the not so distant past ... I'd imagine the K-1ii was upgraded at the same time ... it's a very handy feature
01-28-2024, 02:46 PM - 1 Like   #68
FWIW...
Works for M42 also! And beyond Takumars.
Just playing around with a 1954 A. Schacht München Travenar 135 f/3.5.
Focus and then drop the aperture down to whatever and the camera meters it properly.
I can be lazy with old lenses now
01-28-2024, 03:09 PM   #69
ehrwien's Avatar
I guess it will not work on the K-1 (I)?
01-28-2024, 03:20 PM - 2 Likes   #70
jcdoss's Avatar
The camera (K-1 mII) won't stop the lens down in any automatic mode. You're shooting wide open regardless of where you've set your aperture.
01-29-2024, 12:31 AM   #71
Kevin B123's Avatar
QuoteOriginally posted by jcdoss Quote
I set the aperture on the lens, not the body and the camera makes a correct exposure, whether I have set f1.7 or f16.
The exposure time varies, it is showing Av on the back the camera even in P or TV mode.
01-29-2024, 12:53 AM - 1 Like   #72
pschlute's Avatar
With a manual lens like the M 50/1.7, putting the camera to any of the auto modes will cause the camera to revert to Av.
In Av mode the camera will give a correct exposure by adjusting shutter speed, but always uses wide open aperture. It wont stop down the lens even if you put the aperture ring to f22.
The only way to have the lens stop down is to use M mode. This has been the way all Pentax DSLRs worked up until the K-3 III. That model operates differently.
01-29-2024, 01:51 AM   #73
Kevin B123's Avatar
I don't understand this.
If I have physically set the lens aperture on the lens aperture ring to say f11, and I obtain a correct exposure it cannot use a wide open aperture?
01-29-2024, 02:16 AM   #74
Yes it can, if the ISO is low enough to allow the camera to raise the shutter speed sufficiently to give a correct exposure.
You'd need to check the EXIF of the image to confirm that the shutter speed and ISO are consistent with the aperture you set for the given light conditions ... suspicion is that the ISO will be low and shutter speed inordinately high.
01-29-2024, 02:49 AM   #75
Lord Lucan's Avatar
QuoteOriginally posted by ehrwien Quote
It does, to my surprise.
approach, av, button, camera, camera functions, cameras, display, dslr, estate, f5.6, five, function, images, k-3, k3, level, mode, modes, ovf, people, photography, post, settings, shutter, user, week
Now that I have discovered P-TTL will it become a crutch? funkythiru Troubleshooting and Beginner Help 11 07-06-2018 05:12 PM
Just discovered the ME Super but worried I may have a faulty camera and/or winder MewersDad Troubleshooting and Beginner Help 4 07-03-2016 03:09 PM
Downsizing and discovered we have a pristine pentax LX joylovessailing Welcomes and Introductions 9 03-12-2016 02:46 PM
Testing SR and other functions on K-3 after repair realitarian Pentax K-3 & K-3 II 5 07-09-2015 09:12 AM
I have discovered RAW with this shot - My jaw is on the floor!! photoleet Pentax K-5 & K-5 II 55 07-27-2012 03:26 PM
All times are GMT -7. The time now is 11:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
