11-01-2008, 09:48 AM   #1
K10 Quality issues
My K10 ceased functioning the first day of my vacation with a memory card read error. Fortunately it was under warranty and while I could not use at all during the vacation, the CF pins were replaced right before the warranty expired.
The camera came back from the repair shop (by now the warranty had expired), I took about 20 pictures and then got the same error message. This time the main PCB unit and the CF unit needs replacement ($359.34).
I am really getting concerned about the overall quality of the camera. Did anybody have similar problems or experiences?
Thanks,
Hermann
11-01-2008, 12:03 PM   #2
I'm sorry to hear about your issues.
A K100d super, 2 K10s and a K20 - no such problem has every occured for me.
11-01-2008, 12:35 PM   #3
Ash
Community Manager
Ash's Avatar
Not here either.
Had a K100D and a K10D for over 2.5yrs combined - never a glitch.
Yours is unfortunate. Hope it works out.
11-01-2008, 01:07 PM   #4
offertonhatter's Avatar
seems like an unusual problem. My K10D is over 18 months old and over 18000 shots, and no problem at all. I am sure that it is a one off, and once it is back from repair, it will be fine.
11-01-2008, 01:22 PM   #5
My K10D has done north of 40,000 actuations over about 2 years and the only issue I've had (on, like 4 shots) is a 'unique' colour-effect monochrome green. Those instances were in nighttime outdoor conditions, and turning the camera off and then on again worked fine to restore it to normal working order. Otherwise, the thing has worked and is working beautifully. Sorry to hear about your problem, though
11-01-2008, 02:30 PM   #6
QuoteOriginally posted by Hermann Lahr Quote
Thanks,
Hermann
sorry to head about your delima, the only problem i have encountered with mine is that i dont get to use it as often as i want
Dave
11-01-2008, 02:40 PM   #7
Damn Brit
Guest
I think your case is just sheer bad luck.
Soory man, that sucks.
11-01-2008, 03:14 PM   #8
Shashinki's Avatar
Am I the only one wondering why he got a problem with the CF pins and CF unit on a camera that uses SD cards?? Or does CF stand for something other than Compact Flash memorycards in this case?
If you are using CF cards in your K10D, no wonder you are having problems
11-01-2008, 07:55 PM   #9
Marc Sabatella's Avatar
QuoteOriginally posted by Shashinki Quote
Am I the wondering why he got a problem with the CF pins and CF unit on a camera that uses SD cards?? Or does CF stand for something other than Compact Flash memorycards in this case?
I think we all assumed he meant SD. But this does suggest something else - maybe there is something wrong the card that is screwing up the camera? Although from what I understand, SD is less problematic than CF in this regard.
Anyhow, this is definitely the first I've heard of a problem like this in my 3+ years with Pentax and visiting the various online forums pretty obsessively...
11-01-2008, 09:33 PM   #10
Seven months and 8,500 shotsw with no problems at all.
11-02-2008, 04:15 AM   #11
borno's Avatar
Hermann, If pentax fixed your camera the repair is warranted for another year.
11-02-2008, 06:46 AM   #12
Hi there,
Definitely using SD cards. CF pins is what the Pentax shop calls them.
It would have been too easy.
Hermann
11-02-2008, 06:53 AM   #13
Lowell Goudge's Avatar
Thanks,
Hermann
I think you can consider the repair by pentax was not done, as the same fault came back immediately upon return, and as a result the camera is still under warranty.
camera, cf, dslr, error, k10, photography, quality, unit, vacation, warranty
43mm 1.9 - Made in Japan Vs. Made Wherever today? Quality Issues? PentaxForums-User Pentax SLR Lens Discussion 6 05-09-2010 01:49 PM
Do C and N have as many lens quality issues? Mindflux Pentax SLR Lens Discussion 19 10-27-2008 11:59 AM
K10 issues in Bright Sun deludel Pentax DSLR Discussion 5 03-24-2008 01:27 PM
K10 auto focus issues strictlypentax Pentax DSLR Discussion 11 10-09-2007 09:04 AM
K10 quality control issues? slip Pentax DSLR Discussion 15 02-08-2007 03:07 AM
All times are GMT -7. The time now is 11:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
