Some while ago I asked about the K-70 and KP using a different Remote Control cable to the earlier cameras and it was suggested I could use a 2.5mm to 3.5mm jack adaptor, readily and cheaply available!
Such an item was ordered (from far far away) and was eventually received and put on one side until wanted/needed.
So now I come to want to use my old cable release on my K-70, duly fit the adaptor, only to find that the resulting assembly won't work.
Then I realised that where the earlier cameras use a 3-pole 2.5mm plug, presumably two signals + ground, the newer cameras sneakily use a 4-pole 3.5mm plug
I'm not finding reference to a suitable adaptor being available. Does anyone know of such an adaptor that actually works, or am I stuck with having to buy another remote control cable?
