Originally posted by madisonphotogrl I know this may be a newbie question... but when I connected my K10D to my Mac my camera was in PC mode on LCD but my macbook did not recognize it had something connected to its usb. Are they compatible?
Lets' start with the basics. It's not a matter of the computer recognizing the K10D. No camera itself (any brand) is recognized by a computer (any brand). What is recognized is 1) the card reader within the camera as an external USB storage device and 2) camera signals traveling through the USB port (see last paragraph).
Before proceeding, make certain a properly formatted memory card is inserted into the camera. This memory card should be formatted only within the camera, not within a computer. Afterwards, install the Pentax software and connect your camera as per the instructions given in the manual. Turn off the camera while making the physical hardware connection (connecting the USB cable) and then on again afterwards. Your computer should respond as described in the manual. If not, proceed to the next paragraph.
If your computer is not seeing the K10D's card reader, check the settings on your computer for external USB storage devices. Tracing this problem is absolutely no different than tracing down a problem with any other external USB storage device (hard drive, CD drive, etc). You should be able to easily find websites providing advice on problem solving with USB devices on the Macintosh. If you have an older Mac (many years old), you could try the PC-F mode on the K10D which slows it's USB connection down to USB 1.1 speeds. However, not entirely sure this mode will work with a Mac (always try PC-mode first). If all else fails, you can access your images by removing the memory card from the camera and inserting it into another card reader attached to, or built into, your Macintosh.
The computer may or may not see a name associated with the K10D card reader. That's dependant on the name given the memory card itself. The K10D does not give a name for memory cards while formatting, so the memory card may appear as "No_Name" on the computer. You can freely change the name of the card (folder name) using your computer.
Of course, since several here mentioned supported Raw formats, please note the physical hardware connection is an entirely different matter than recognizing the Pentax Raw file formats. You cannot see the files without a successful hardware connection first, with the latter (an unsuccessful hardware connection) the primary concern here.
The camera signals through the USB port are unrelated to the computer recognizing the card reader within the K10D, but included to give a wider understanding of events between the computer and camera. The computer does not understand those signals, but simply passes them between software and the USB port. Special software is needed to interprete and use those signals. Pentax provides a software product, called "Pentax Remote Assistant," which can use those signals to monitor your camera, change settings, and take images. Not certain this software is compatible with the Macintosh, but you can check and download Pentax Remote Assistant on the Pentax website.
stewart
