Originally posted by mapov No answers.
Nobody had the ist ds, then/and the K10?
I had the DS and now the K200D, which is larger the same as the K10D on the inside if not the outside. But I am familiar with most of the differences.
Things the K10D does better:
- Shake reduction (so big, even if it did nothing else, it would be worth it right there)
- More resolution (I'm finding this more significant than I thought I would)
- Weather sealing
- Front dial and other extra controls (you can set ISO without looking at the LCD!)
- Orientation sensor, so pictures are rotated correctly automatically
(I know the K200D has this, but I'm pretty sure the K10D does too)
- Nicer LCD
Things the DS does better:
- Less noise at high ISO, maybe (older K10D's seem to suffer more from this)
- Smaller/lighter (not an advantage in everyone's eyes, of course)
- Takes AA batteries (not an advantage in everyone's eyes, either)
Overall, I consider the K200D a big step up from the DS, and I had to give up the somewhat nicer viewfinder of the DS. With the K10D, you get to keep the viewfinder. So unless you find the size or noise a big issue, you'll probably also find the K10D a big improvement. You might want to take a test picture or two at high ISO to see if the K10D's they have at the store are OK. My K200D does as well as high ISO as my DS did when viewing images at the same sizes, and it's the same sensor as the K10D, but I've seen some images from earlier units of the K10D that were terrible at high ISO.
By the way, you mentioned somethng about the sensor being the same. I don't know if you thought the K10D sensor was the same as the DS, but it isn't. DS is 6MP, 10D is 10MP.
