06-28-2020, 11:46 PM   #1
Belcik's Avatar
Recording Video: signal chain
So, I tried recording video with KP and lt 43.
The thing here is that it is music video, so the sound matters. Within signal chain, I recorded separate sound file and merged in DaVinci Resolve. The result:
However I fell that workflow is complex. Any luck and experience with recording good quality sound into the MOV in camera?
1. Clear, that w/o backing track, the signal chain would go into KP mic input. As I read, the MOV stores sound in sowt format (AIFF??) and this should be a good quality. Anyone did sth similar?
2. With Backing track - I cannot jump over the Video mastering (even if it is ridiculisy simple in DaVinci) however, Point #1 would help a little bit.
3. Recording all in once - not possible... Pentax KP cannot stream directly to PC. This brings back the idea of using webcam, however with such a set of glasses I would prefer avoiding this
Suggestions?
06-29-2020, 04:20 PM   #2
hcc
hcc's Avatar
A good external mic is a must IMO. I do shoot outdoor sounds with my K-3 and I use a Rode Videomic Pro (i.e. a small shotgun). I am happy of the combo for my work, including down a sound frequency analysis (I am most interested in the 10-100 Hz range).
Note sure if the comment could help.
06-29-2020, 04:55 PM   #3
clackers's Avatar
Ok, so when pros make music videos they don't use the incamera sound at all. It’s an inferior in all brands to an external recorder. Remember to use a clapper board or even clap your own hands or two drumsticks together so you can sync the sound and video files together in your editing software.
06-29-2020, 06:46 PM   #4
sqlngtr's Avatar
The signal is from 2 mic's to a mic preamp to a Boss 1600CD recorder so I could add reverb, delay, and EQ and mix the two mic's. I use the headphone line out from the recorder to the K-1 mic in and recorded direct to the camera sd card and edited in Davinci Resolve. To prevent the signal from blowing out I dialed the K-1 mic level down to 1. The guitar mic is a great stage mic but not a great recording mic so I have ordered a Lauton Audio 320 to fix that. For my music video's I find the sound quality to be acceptable. So it is doable but if you want to multi track you can still use the recorder track and overdub in Davinci.
06-30-2020, 03:25 AM   #5
Belcik's Avatar
Ok, so when pros make music videos they don't use the incamera sound at all. Its an inferior in all brands to an external recorder. Remember to use a clapper board or even clap your own hands or two drumsticks together so you can sync the sound and video files together in your editing software.
Well, guitar is recorded in line, so instead of clapping i hit strings, so the audio in KP that is in sync with video registered it. I do not use amp, so during recording i hear only what is in headphones.
Отправлено с моего iPhone используя Tapatalk
---------- Post added 2020-06-30 at 13:27 ----------
QuoteOriginally posted by sqlngtr Quote
YouTube The signal is from 2 mic's to a mic preamp to a Boss 1600CD recorder so I could add reverb, delay, and EQ and mix the two mic's. I use the headphone line out from the recorder to the K-1 mic in and recorded direct to the camera sd card and edited in Davinci Resolve. To prevent the signal from blowing out I dialed the K-1 mic level down to 1. The guitar mic is a great stage mic but not a great recording mic so I have ordered a Lauton Audio 320 to fix that. For my music video's I find the sound quality to be acceptable. So it is doable but if you want to multi track you can still use the recorder track and overdub in Davinci.
Ok, so you basically answered my core question. You use line out signal and route to mic input in K1. This way your video and audio are in sync and sound quality is high. Correct?
06-30-2020, 06:32 AM   #6
acoufap's Avatar
QuoteOriginally posted by Belcik Quote
Besides the mic the AD converter is critical. Im pretty sure that in-camera AD converters arent the best. But if youre satisfied with the sound, noise characteristics and possible signal delay ... why not.
06-30-2020, 08:51 AM - 1 Like   #7
sqlngtr's Avatar
Yup. The better the mic I use to capture the sound the better the recording quality. Mic's are a lot like len's, the good ones cost a lot...
---------- Post added 06-30-20 at 10:01 AM ----------
As far as quality goes, you heard what I got from the video. It is good enough for me. Weather it is good enough for you is up to you. I'm not a recording artist nor do I have a budget to reflect that. It is getting better with practice but I'm in no danger of kicking Garth Brooks off his spot on the mountain.
camera, chain, dslr, iphone, k-1, kp, line, mic, mov, photography, post, quality, recorder, sound, sync, tapatalk, track, video
Abstract Hand Signal? Kerrowdown Post Your Photos! 6 05-17-2020 02:16 PM
Video recording stopping unexpectedly! tilde Pentax KP 5 04-22-2020 12:19 AM
Video mode - "selfie" recording focus mlines Pentax K-70 3 10-15-2019 06:29 AM
What's a good and light video camera for vlogging/recording Youtube videos? kierlan Non-Pentax Cameras: Canon, Nikon, etc. 7 10-10-2018 04:15 PM
PENTAX K-5 at the Wild... (a Short Video Recording) ogunturkay Pentax K-5 & K-5 II 4 10-19-2011 01:12 AM
All times are GMT -7. The time now is 03:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
