Originally posted by vector It already is possible. I do it all the time with my Samyang 85 1.4 and 35 1.4. It is the same as focus fine tuning your af lenses but with a little inconvenience. The camera will remember settings for the AF lenses but not manual lenses so you have to use "Apply All" in the Fine Adjustment menu. The painful part is that when you take your MF lens off the camera you need to set this back to "Apply One". So I fine tune all my MF lenses and keep a list of the focus adjustments for each one on my phone and apply them when I put the lens on. This way the focus indicator is just as accurate for MF as it is for AF. I have pretty good success with this even photographing my kids. The only difference then between AF and MF is that you are turning the focus ring rather than camera but the focus indicator is just as accurate.
Originally posted by stevebrot BMC pretty much wrote the book on that technique, FWIW.
Originally posted by vector Haha, oh well at least I am reminding all the other readers. Some folks will read his comment and think accurate AF in the viewfinder is not possible at all. I see comments griping about it too often, so I decided this time to respond. It's not perfect, still uses the f2.8 AF points like the AF lenses do, but it's also not terrible and can work quite well.
Yes, I'm familiar with that approach
I appreciate the good intentions, though
The "problem" with this approach ("problem" in quotes, because it's a technical limitation rather than a flaw), is that even with properly calibrated AF fine tuning, the focus confirmation will light within a
small range rather than one precise "in focus" position. To achieve the best focus accuracy, you have to rock the lens' focus ring back and forth to find the limits of that range, then set it at the estimated the mid-point. With a bit of practice, it's certainly possible to be acceptably and repeatedly accurate, but I'd love to have an OVF that offered greater precision in manual focusing...
